[GeoNode-users] migration geonode 2.4 to 3.1 ubuntu 14.04
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Mon Jan 25 01:35:55 PST 2021
I mean (if possible) install on a brand new Ubuntu 20 server, just to be
sure you won't lose the previous version and data.
Il giorno lun 25 gen 2021 alle ore 10:34 Enzo Cocca <enzo.ccc at gmail.com> ha
scritto:
> Sounds good!
> Just to be sure: when you say "make a new installation on another machine"
> it means after geonode db backup I can upgrade ubuntu to bionic version
> example, I can install geonode 3.1 and then make the migration?
> E
> Il giorno lun 25 gen 2021 alle ore 10:17 Alessio Fabiani <
> alessio.fabiani at geo-solutions.it> ha scritto:
>> Hello Enzo,
>> sure it is possible, even though not that easy to achieve.
>> I would suggest to:
>> 1. Backup the DB
>> 2. Make a new installation of GeoNode 3.1 on another machine
>> 3. Restore the DB and run migrations
>> 4. Fix the DB errors while occurring (this is a boring action that must
>> be done manually, unfortunately)
>> Good luck,
>> A.
>> Il giorno lun 25 gen 2021 alle ore 09:57 Enzo Cocca <enzo.ccc at gmail.com>
>> ha scritto:
>>> Hi people,
>>> I have some questions:
>>> Is it possible to migrate geonode 2.4 to 3.1 on ubuntu 14.04?
>>> If not what you suggest as steps to upgrade geonode and ubuntu?
>>> thanks in advance
>>> Best
>>> E
>>> Enzo Cocca PhD
>>> in "Science and Technology for Archaeology and Cultural Heritage"
>>> ISMEO
>>> International Association of Mediterranean and Oriental Studies
>>> mail: enzo.ccc at gmail.com
>>> cell: +393495087014
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>> phone: +39 0584 962313
>> fax: +39 0584 1660272
>> mob: +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
> Enzo Cocca PhD
> ISMEO
> cell: +393495087014
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210125/a25f5d3b/attachment-0001.html>
More information about the geonode-users
