[GeoNode-users] migration geonode 2.4 to 3.1 ubuntu 14.04
Enzo Cocca enzo.ccc at gmail.com
Mon Jan 25 01:37:24 PST 2021
Thanks for the tip!
I will let you know
E
Il giorno lun 25 gen 2021 alle ore 10:36 Alessio Fabiani <
alessio.fabiani at geo-solutions.it> ha scritto:
> I mean (if possible) install on a brand new Ubuntu 20 server, just to be
> sure you won't lose the previous version and data.
> Il giorno lun 25 gen 2021 alle ore 10:34 Enzo Cocca <enzo.ccc at gmail.com>
> ha scritto:
>> Sounds good!
>> Just to be sure: when you say "make a new installation on another
>> machine" it means after geonode db backup  I can upgrade ubuntu to bionic
>> version example, I can  install geonode 3.1  and then make the migration?
>> E
>> Il giorno lun 25 gen 2021 alle ore 10:17 Alessio Fabiani <
>>> Hello Enzo,
>>> sure it is possible, even though not that easy to achieve.
>>> I would suggest to:
>>> 1. Backup the DB
>>> 2. Make a new installation of GeoNode 3.1 on another machine
>>> 3. Restore the DB and run migrations
>>> 4. Fix the DB errors while occurring (this is a boring action that must
>>> be done manually, unfortunately)
>>> Good luck,
>>> A.
>>> Il giorno lun 25 gen 2021 alle ore 09:57 Enzo Cocca <enzo.ccc at gmail.com>
>>> ha scritto:
>>>> Hi people,
>>>> I have some questions:
>>>> Is it possible to migrate geonode 2.4 to 3.1 on ubuntu 14.04?
>>>> If not what you suggest as steps to upgrade geonode and ubuntu?
>>>> thanks in advance
>>>> Best
>>>> E
>>>> Enzo Cocca PhD
>>>> in "Science and Technology for Archaeology and Cultural Heritage"
>>>> ISMEO
>>>> International Association of Mediterranean and Oriental Studies
>>>> mail: enzo.ccc at gmail.com
>>>> cell: +393495087014
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>> phone: +39 0584 962313
>>> fax:     +39 0584 1660272
>>> mob:   +39 331 6233686
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
>> Enzo Cocca PhD
>> ISMEO
>> cell: +393495087014
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
Enzo Cocca PhD
ISMEO
cell: +393495087014
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210125/e17c05c1/attachment-0001.html>
More information about the geonode-users mailing list
