[GeoNode-users] Raster series as temporal layer
Alessio Fabiani alessio.fabiani at geo-solutions.it
Tue Jan 26 01:14:14 PST 2021
Hi Alexander,
you might need to enable this on layer metadata
[image: image.png]
Il giorno mar 26 gen 2021 alle ore 09:57 Alexander Petkov <
greenkov at gmail.com> ha scritto:
> Any ideas as to why the Timeline widget is not visible on a map for a
> Layer?
> This is the result from a wmts DescribeDomains request:
> <Domains version="1.1">
> <SpaceDomain>
> <BoundingBox CRS="EPSG:4326" minx="-156.661" miny="-45.642" maxx="178.039"
> maxy="74.034"/>
> </SpaceDomain>
> <DimensionDomain>
> <ows:Identifier>time</ows:Identifier>
> <Domain>2020-09-08T00:00:00.000Z,2020-09-09T00:00:00.000Z</Domain>
> <Size>2</Size>
> </DimensionDomain>
> </Domains>
> Then I ran python manage.py updatelayers.
> However, upon viewing the layer on a map, the Timeline widget does not
> appear:
> https://pasteboard.co/JLoXmYkQ.png
> Also, is it possible to display a Timeline widget for Raster layers
> (imagemosaic) with a time dimension?
> Thank you in advance!!
> Alex
> On Thu, Jan 21, 2021 at 6:51 AM Alexander Petkov <greenkov at gmail.com>
> wrote:
>> I think this is what I am looking for:
>> https://docs.geonode.org/en/stable/usage/managing_maps/exploring_maps/timeline.html
>> On Thu, Jan 21, 2021 at 6:38 AM Alexander Petkov <greenkov at gmail.com>
>> wrote:
>>> I mean that in the metadata is visible start date/end date for the
>>> layer.
>>> On Thu, Jan 21, 2021 at 6:35 AM Simone Giannecchini <
>>> simone.giannecchini at geo-solutions.it> wrote:
>>>> Hi Alexander,
>>>> what do you mean by " Now I am wondering if it is possible to expose
>>>> the temporal extent  as well, in the metadata viewable in Geonode "?
>>>> Regards,
>>>> Simone Giannecchini
>>>> GeoServer Professional Services from the experts!
>>>> Visit http://bit.ly/gs-services for more information.
>>>> Ing. Simone Giannecchini
>>>> @simogeo
>>>> Founder/Director
>>>> GeoSolutions S.A.S.
>>>> Via di Montramito 3/A
>>>> 55054  Massarosa (LU)
>>>> Italy
>>>> phone: +39 0584 962313
>>>> fax:     +39 0584 1660272
>>>> mob:   +39  333 8128928
>>>> http://www.geo-solutions.it
>>>> http://twitter.com/geosolutions_it
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>>> precisa che ogni circostanza inerente alla presente email (il suo
>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>> This email is intended only for the person or entity to which it is
>>>> addressed and may contain information that is privileged, confidential or
>>>> otherwise protected from disclosure. We remind that - as provided by
>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>> e-mail or the information herein by anyone other than the intended
>>>> recipient is prohibited. If you have received this email by mistake, please
>>>> notify us immediately by telephone or e-mail.
>>>> On Thu, Jan 21, 2021 at 10:12 AM Alexander Petkov <greenkov at gmail.com>
>>>> wrote:
>>>>> Hello Simone and Geonode users:
>>>>> I have configured the Mosaic in Geoserver with Time dimension enabled,
>>>>> and ran the updatelayers command.
>>>>> The layer is recognised and listed in Geonode.
>>>>> Now I am wondering if it is possible to expose the temporal extent  as
>>>>> well, in the metadata viewable in Geonode.
>>>>> Thank you in advance with any pointers,
>>>>> Alex
>>>>> On Wed, Jan 20, 2021 at 11:28 AM Simone Giannecchini <
>>>>>> Hi Alexander,
>>>>>> I think this is more of a GeoServer related question.
>>>>>> If you can set up an ImageMosaic in GeoServer then you can use the
>>>>>> updateLayers management command and have this layer become a GeoNode layer.
>>>>>> Obviously the work is a little more complicated than that, I was just
>>>>>> trying to give you some directions.
>>>>>> There are quite a number of documents around for setting up a raster
>>>>>> time series in GeoServer...
>>>>>> Regards,
>>>>>> Simone Giannecchini
>>>>>> @simogeo
>>>>>> Founder/Director
>>>>>> GeoSolutions S.A.S.
>>>>>> Italy
>>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>>> On Wed, Jan 20, 2021 at 1:56 PM alexander-petkov <greenkov at gmail.com>
>>>>>> wrote:
>>>>>>> I have the same question--Is it possible to expose the Time
>>>>>>> dimension for a
>>>>>>> raster layer in Geonode?
>>>>>>> The layer is updated daily, so the time dimension changes.
>>>>>>> Kind regards,
>>>>>>> Alex
>>>>>>> Sent from:
>>>>>>> http://osgeo-org.1560.x6.nabble.com/GeoNode-users-f5185389.html
>>>>>>> _______________________________________________
>>>>>>> geonode-users mailing list
>>>>>>> geonode-users at lists.osgeo.org
>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
mob:   +39 331 6233686
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210126/536e9597/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210126/536e9597/attachment-0001.png>
More information about the geonode-users mailing list
