[GeoNode-users] Raster series as temporal layer
Alexander Petkov
greenkov at gmail.com
Tue Jan 26 02:14:50 PST 2021
Thanks Alessio, that did it!!
Alex
On Tue, Jan 26, 2021 at 2:14 AM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Hi Alexander,
> you might need to enable this on layer metadata
> [image: image.png]
> Il giorno mar 26 gen 2021 alle ore 09:57 Alexander Petkov <
> greenkov at gmail.com> ha scritto:
>> Any ideas as to why the Timeline widget is not visible on a map for a
>> Layer?
>> This is the result from a wmts DescribeDomains request:
>> <Domains version="1.1">
>> <SpaceDomain>
>> <BoundingBox CRS="EPSG:4326" minx="-156.661" miny="-45.642"
>> maxx="178.039" maxy="74.034"/>
>> </SpaceDomain>
>> <DimensionDomain>
>> <ows:Identifier>time</ows:Identifier>
>> <Domain>2020-09-08T00:00:00.000Z,2020-09-09T00:00:00.000Z</Domain>
>> <Size>2</Size>
>> </DimensionDomain>
>> </Domains>
>> Then I ran python manage.py updatelayers.
>> However, upon viewing the layer on a map, the Timeline widget does not
>> appear:
>> https://pasteboard.co/JLoXmYkQ.png
>> Also, is it possible to display a Timeline widget for Raster layers
>> (imagemosaic) with a time dimension?
>> Thank you in advance!!
>> Alex
>> On Thu, Jan 21, 2021 at 6:51 AM Alexander Petkov <greenkov at gmail.com>
>> wrote:
>>> I think this is what I am looking for:
>>> https://docs.geonode.org/en/stable/usage/managing_maps/exploring_maps/timeline.html
>>> On Thu, Jan 21, 2021 at 6:38 AM Alexander Petkov <greenkov at gmail.com>
>>> wrote:
>>>> I mean that in the metadata is visible start date/end date for the
>>>> layer.
>>>> On Thu, Jan 21, 2021 at 6:35 AM Simone Giannecchini <
>>>> simone.giannecchini at geo-solutions.it> wrote:
>>>>> Hi Alexander,
>>>>> what do you mean by " Now I am wondering if it is possible to expose
>>>>> the temporal extent as well, in the metadata viewable in Geonode "?
>>>>> Regards,
>>>>> Simone Giannecchini
>>>>> GeoServer Professional Services from the experts!
>>>>> Visit http://bit.ly/gs-services for more information.
>>>>> Ing. Simone Giannecchini
>>>>> @simogeo
>>>>> Founder/Director
>>>>> GeoSolutions S.A.S.
>>>>> Via di Montramito 3/A
>>>>> 55054 Massarosa (LU)
>>>>> Italy
>>>>> phone: +39 0584 962313
>>>>> fax: +39 0584 1660272
>>>>> mob: +39 333 8128928
>>>>> http://www.geo-solutions.it
>>>>> http://twitter.com/geosolutions_it
>>>>> Con riferimento alla normativa sul trattamento dei dati personali
>>>>> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”),
>>>>> si precisa che ogni circostanza inerente alla presente email (il suo
>>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>>> This email is intended only for the person or entity to which it is
>>>>> addressed and may contain information that is privileged, confidential or
>>>>> otherwise protected from disclosure. We remind that - as provided by
>>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>>> e-mail or the information herein by anyone other than the intended
>>>>> recipient is prohibited. If you have received this email by mistake, please
>>>>> notify us immediately by telephone or e-mail.
>>>>> On Thu, Jan 21, 2021 at 10:12 AM Alexander Petkov <greenkov at gmail.com>
>>>>> wrote:
>>>>>> Hello Simone and Geonode users:
>>>>>> I have configured the Mosaic in Geoserver with Time dimension
>>>>>> enabled, and ran the updatelayers command.
>>>>>> The layer is recognised and listed in Geonode.
>>>>>> Now I am wondering if it is possible to expose the temporal extent
>>>>>> as well, in the metadata viewable in Geonode.
>>>>>> Thank you in advance with any pointers,
>>>>>> Alex
>>>>>> On Wed, Jan 20, 2021 at 11:28 AM Simone Giannecchini <
>>>>>>> Hi Alexander,
>>>>>>> I think this is more of a GeoServer related question.
>>>>>>> If you can set up an ImageMosaic in GeoServer then you can use the
>>>>>>> updateLayers management command and have this layer become a GeoNode layer.
>>>>>>> Obviously the work is a little more complicated than that, I was
>>>>>>> just trying to give you some directions.
>>>>>>> There are quite a number of documents around for setting up a raster
>>>>>>> time series in GeoServer...
>>>>>>> Regards,
>>>>>>> Simone Giannecchini
>>>>>>> @simogeo
>>>>>>> Founder/Director
>>>>>>> GeoSolutions S.A.S.
>>>>>>> Italy
>>>>>>> On Wed, Jan 20, 2021 at 1:56 PM alexander-petkov <greenkov at gmail.com>
>>>>>>> wrote:
>>>>>>>> I have the same question--Is it possible to expose the Time
>>>>>>>> dimension for a
>>>>>>>> raster layer in Geonode?
>>>>>>>> The layer is updated daily, so the time dimension changes.
>>>>>>>> Kind regards,
>>>>>>>> Alex
>>>>>>>> Sent from:
>>>>>>>> http://osgeo-org.1560.x6.nabble.com/GeoNode-users-f5185389.html
>>>>>>>> _______________________________________________
>>>>>>>> geonode-users mailing list
>>>>>>>> geonode-users at lists.osgeo.org
>>>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> mob: +39 331 6233686
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210126/61871d1e/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210126/61871d1e/attachment-0001.png>
More information about the geonode-users
