[GeoNode-users] HOW TO SECURELY INTERACT WITH GEONODE API
edgar mlowe mloweedgar0 at gmail.com
Mon Jul 19 00:58:05 PDT 2021
Thank you Alessio,
I figured out that I can also use basic auth to access genode API, I tested
with Postman it worked. My Only problem now is that When I call Geonode API
from my react app(using basic auth i.e passing base64 encoded string of
username and password in authorization header) I do get cors. but if I make
a http call to Geonode API without passing the authorization header(basic
auth), I don't get  the cors.
Do you have an idea on what configuration I might be  missing in the
Genode? I have already set CORS_ORIGIN_ALLOW_ALL=True in .env. I have
installed Geonode using docker.
On Mon, Jul 19, 2021 at 10:32 AM Alessio Fabiani <
alessio.fabiani at geo-solutions.it> wrote:
> Hello Edgar,
> it depends on how you are using the APIs. In a browser session, once you
> successfully authenticate on Django, the session cookie will automatically
> authenticate you.
> Once authenticated, if you need to know about your "access_token" just hit
> the endpoint https://<geonode>/api/o/v4/userinfo
> Alessio.
> Il giorno sab 17 lug 2021 alle ore 17:07 edgar mlowe <
> mloweedgar0 at gmail.com> ha scritto:
>> Hello Everyone,
>> Iam using Geonode REST API to integrate my custom web application, I'm
>> facing the challenge on how to get for example access token that I can use
>> in my authorization hear to access protected resources.
>> Anyone who can guide me on authentication/authorization regarding the
>> GEONODE API I will appriciate so much.  Iam using Geonode 3.2.0.
>> Kind regards,
>> Edgar.
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210719/e8f9dc60/attachment-0001.html>
More information about the geonode-users mailing list
