[GeoNode-users] [GeoNode 3.2] direct link to the map
Adrian Bajer
bajeradr at gmail.com
Tue May 4 23:15:50 PDT 2021
Hello Alessio,
Thank you for the hint.
Do you think that idea of such plugin is good proposal for opening a new
GNIP on a github?
Best regards,
*Adrian Bajer, MA*
*Department of Historical Atlas*
Institute of History, Polish Academy of Sciences
Rynek Starego Miasta 29/31
00-272 Warsaw, Poland
e-mail: bajeradr at gmail.com
pt., 30 kwi 2021 o 15:50 Alessio Fabiani <alessio.fabiani at geo-solutions.it>
napisał(a):
> Hello Adrian,
> so I looked around but currently haven't found a straight way to achieve
> that in MapStore.
> That would probably need the development of a specific plugin or
> something. I'll try to look further and see what I can find.
> In the meantime, the quickest solution that comes into my mind would be to
> create a "Map" zoomed to the point of interest and use the link to the Map.
> It's a kind of workaround, not sure it matches your needs.
> Regards,
> Alessio.
> Il giorno gio 29 apr 2021 alle ore 08:31 Adrian Bajer <bajeradr at gmail.com>
> ha scritto:
>> Hello,
>> This is my question from yesterday's Webinar GeoNode 3.2.
>> Is it possible in GeoNode 3.2 to create a direct link to a certain point
>> on the map with coordinates and zoom (like in "share" option in MapStore)?
>> Best regards,
>> *Adrian Bajer, MA*
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts! Visit
> http://goo.gl/it488V for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions S.A.S.
> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 331 6233686
> http://www.geo-solutions.it
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210505/c17a5ab4/attachment.html>
More information about the geonode-users
