[GeoNode-users] [GeoNode 3.2] direct link to the map
Alessio Fabiani
alessio.fabiani at geo-solutions.it
Wed May 5 04:08:54 PDT 2021
Hello Adrian,
maybe a feature request is sufficient. GNIPs are mostly used for big
architectural changes.
The first thing to do would be to hear from the mapstore community if maybe
there's already a feature to create a permalink to a single position. I'm
pretty sure there is already.
Alessio.
Il giorno mer 5 mag 2021 alle ore 08:15 Adrian Bajer <bajeradr at gmail.com>
ha scritto:
> Hello Alessio,
> Thank you for the hint.
> Do you think that idea of such plugin is good proposal for opening a new
> GNIP on a github?
> Best regards,
> *Adrian Bajer, MA*
> *Department of Historical Atlas*
> Institute of History, Polish Academy of Sciences
> Rynek Starego Miasta 29/31
> 00-272 Warsaw, Poland
> e-mail: bajeradr at gmail.com
> pt., 30 kwi 2021 o 15:50 Alessio Fabiani <alessio.fabiani at geo-solutions.it>
> napisał(a):
>> Hello Adrian,
>> so I looked around but currently haven't found a straight way to achieve
>> that in MapStore.
>> That would probably need the development of a specific plugin or
>> something. I'll try to look further and see what I can find.
>> In the meantime, the quickest solution that comes into my mind would be
>> to create a "Map" zoomed to the point of interest and use the link to the
>> Map.
>> It's a kind of workaround, not sure it matches your needs.
>> Regards,
>> Alessio.
>> Il giorno gio 29 apr 2021 alle ore 08:31 Adrian Bajer <bajeradr at gmail.com>
>> ha scritto:
>>> Hello,
>>> This is my question from yesterday's Webinar GeoNode 3.2.
>>> Is it possible in GeoNode 3.2 to create a direct link to a certain point
>>> on the map with coordinates and zoom (like in "share" option in MapStore)?
>>> Best regards,
>>> *Adrian Bajer, MA*
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> GeoServer Professional Services from the experts! Visit
>> http://goo.gl/it488V for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions S.A.S.
>> Via di Montramito 3/A - 55054 Massarosa (LU) - Italy
>> phone: +39 0584 962313
>> fax: +39 0584 1660272
>> mob: +39 331 6233686
>> http://www.geo-solutions.it
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
@alfa7691
GeoSolutions S.A.S.
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210505/3bc2bd42/attachment-0001.html>
More information about the geonode-users
