[GeoNode-users] [GeoNode 3.2] direct link to the map
Adrian Bajer bajeradr at gmail.com
Tue May 11 01:28:29 PDT 2021
Hello Alessio,
Ok, I will ask MapStore community too.
However, to make things clear for me: in standalone MapStore there is
plugin "share" where user can obtain a direct link to a single position on
a map.
I suppose that the share plugin is not implemented in GeoNode due to
different urls system. GeoNode can not take xy coordinates as parameters in
url and set them as a center of a map. Am I right?
Best regards,
*Adrian Bajer, MA*
*Department of Historical Atlas*
Institute of History, Polish Academy of Sciences
Rynek Starego Miasta 29/31
00-272 Warsaw, Poland
e-mail: bajeradr at gmail.com
śr., 5 maj 2021 o 13:09 Alessio Fabiani <alessio.fabiani at geo-solutions.it>
napisał(a):
> Hello Adrian,
> maybe a feature request is sufficient. GNIPs are mostly used for big
> architectural changes.
> The first thing to do would be to hear from the mapstore community if
> maybe there's already a feature to create a permalink to a single position.
> I'm pretty sure there is already.
> Alessio.
> Il giorno mer 5 mag 2021 alle ore 08:15 Adrian Bajer <bajeradr at gmail.com>
> ha scritto:
>> Hello Alessio,
>> Thank you for the hint.
>> Do you think that idea of such plugin is good proposal for opening a new
>> GNIP on a github?
>> Best regards,
>> *Adrian Bajer, MA*
>> pt., 30 kwi 2021 o 15:50 Alessio Fabiani <
>> alessio.fabiani at geo-solutions.it> napisał(a):
>>> Hello Adrian,
>>> so I looked around but currently haven't found a straight way to achieve
>>> that in MapStore.
>>> That would probably need the development of a specific plugin or
>>> something. I'll try to look further and see what I can find.
>>> In the meantime, the quickest solution that comes into my mind would be
>>> to create a "Map" zoomed to the point of interest and use the link to the
>>> Map.
>>> It's a kind of workaround, not sure it matches your needs.
>>> Regards,
>>> Alessio.
>>> Il giorno gio 29 apr 2021 alle ore 08:31 Adrian Bajer <
>>> bajeradr at gmail.com> ha scritto:
>>>> Hello,
>>>> This is my question from yesterday's Webinar GeoNode 3.2.
>>>> Is it possible in GeoNode 3.2 to create a direct link to a certain
>>>> point on the map with coordinates and zoom (like in "share" option in
>>>> MapStore)?
>>>> Best regards,
>>>> *Adrian Bajer, MA*
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> GeoServer Professional Services from the experts! Visit
>>> http://goo.gl/it488V for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions S.A.S.
>>> Via di Montramito 3/A - 55054  Massarosa (LU) - Italy
>>> phone: +39 0584 962313
>>> fax:     +39 0584 1660272
>>> mob:   +39 331 6233686
>>> http://www.geo-solutions.it
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
> @alfa7691
> GeoSolutions S.A.S.
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210511/6a0adfe4/attachment-0001.html>
More information about the geonode-users mailing list
