[GeoNode-users] Install Geoserver Plugin in Geonode Docker
Florian Hoedt florian.hoedt at thuenen.de
Wed May 26 00:57:34 PDT 2021
It is not impossible. We do use a modified Dockerfile and locally built the image. We use netCDF and vectortiles plugins. This is our Dockerfile:
https://gist.github.com/gannebamm/f51c5521ddb41a9ef58a55af0e930a9b
You can use that as example for using plugins with the docker based stack. You have to clone and modify this https://github.com/GeoNode/geoserver-docker/tree/2.18.3 and built it locally. If you later run the docker composition for the geonode stack the locally built image will be used.
yours,
Florian
MSc Florian Hoedt
Head Geoinformatics | OpenData Representative
Thünen Institute, Centre for Information Management
Bundesallee 44
38116 Braunschweig
Tel:  +49 531 596-1428
Mobil: +49 162 92 50 275
Fax:  +49 531 596-1499
Mail: florian.hoedt at thuenen.de
Web:  www.thuenen.de
The Johann Heinrich von Thünen Institute, Federal Research Institute for Rural Areas, Forestry and Fisheries – Thünen Institute in brief – consists of 14 specialized institutes that carry out research and provide policy advice in the fields of economy, ecology and technology.
----- Ursprüngliche Mail -----
Von: "irland fardani" <irlan128 at gmail.com>
An: "geonode-users" <geonode-users at lists.osgeo.org>
Gesendet: Mittwoch, 26. Mai 2021 05:41:22
Betreff: [GeoNode-users] Install Geoserver Plugin in Geonode Docker
Dear All,
I already installed geonode 3.2 in docker enviroment.
I want to install MapBox Vector plugin in geoserver, but it not working.
I read in several forum,it imposible to install geoserver plugin in docker.
Has anybody have a trick to install the plugin in geoserver docker?
Thanks before
geonode-users mailing list
https://lists.osgeo.org/mailman/listinfo/geonode-users
More information about the geonode-users mailing list
