[GeoNode-users] Install Geoserver Plugin in Geonode Docker
irland fardani
irlan128 at gmail.com
Wed May 26 03:01:00 PDT 2021
Hi Florian,
Thanks for your reply, big thanks for your help
thanks
On Wed, May 26, 2021 at 2:57 PM Florian Hoedt <florian.hoedt at thuenen.de>
wrote:
> Hi,
> It is not impossible. We do use a modified Dockerfile and locally built
> the image. We use netCDF and vectortiles plugins. This is our Dockerfile:
> https://gist.github.com/gannebamm/f51c5521ddb41a9ef58a55af0e930a9b
> You can use that as example for using plugins with the docker based stack.
> You have to clone and modify this
> https://github.com/GeoNode/geoserver-docker/tree/2.18.3 and built it
> locally. If you later run the docker composition for the geonode stack the
> locally built image will be used.
> yours,
> Florian
> MSc Florian Hoedt
> Head Geoinformatics | OpenData Representative
> Thünen Institute, Centre for Information Management
> Bundesallee 44
> 38116 Braunschweig
> Tel: +49 531 596-1428
> Mobil: +49 162 92 50 275
> Fax: +49 531 596-1499
> Mail: florian.hoedt at thuenen.de
> Web: www.thuenen.de
> The Johann Heinrich von Thünen Institute, Federal Research Institute for
> Rural Areas, Forestry and Fisheries – Thünen Institute in brief – consists
> of 14 specialized institutes that carry out research and provide policy
> advice in the fields of economy, ecology and technology.
> ----- Ursprüngliche Mail -----
> Von: "irland fardani" <irlan128 at gmail.com>
> An: "geonode-users" <geonode-users at lists.osgeo.org>
> Gesendet: Mittwoch, 26. Mai 2021 05:41:22
> Betreff: [GeoNode-users] Install Geoserver Plugin in Geonode Docker
> Dear All,
> I already installed geonode 3.2 in docker enviroment.
> I want to install MapBox Vector plugin in geoserver, but it not working.
> I read in several forum,it imposible to install geoserver plugin in docker.
> Has anybody have a trick to install the plugin in geoserver docker?
> Thanks before
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Irland Fardani M.T.
+628562257785
+6281223261345
Program Studi Perencanaan Wilayah Kota <http://planologi.unisba.ac.id/>
Fakultas Teknik <http://planologi.unisba.ac.id/>
Universitas Islam Bandung <http://planologi.unisba.ac.id/>
Hatur Nuhun
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210526/cea286b5/attachment.html>
More information about the geonode-users
