[GeoNode-users] Setting SSL in Geonode Docker Error
Alexandre Gacon
alexandre.gacon at gmail.com
Thu Sep 16 01:05:49 PDT 2021
Please give a try with the following setting in your env file
LETSENCRYPT_MODE=production
Alexandre
Le jeu. 16 sept. 2021 à 10:03, irland fardani <irlan128 at gmail.com> a écrit :
> Hi Alexandre,
> Yes, I did , bu still got an error
> the issue same with the thread in here
> certbot fails when using LETSENCRYPT_MODE=staging · Issue #203 ·
> GeoNode/geonode-project · GitHub
> <https://github.com/GeoNode/geonode-project/issues/203>
> <http://www.avg.com/email-signature?utm_medium=email&utm_source=link&utm_campaign=sig-email&utm_content=webmail> Virus-free.
> www.avg.com
> <#m_6399733074780055146_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
> On Thu, Sep 16, 2021 at 2:54 PM Alexandre Gacon <alexandre.gacon at gmail.com>
> wrote:
>> I never tried the staging mode for the SSL. Did you try with the
>> production mode instead?
>> Le jeu. 16 sept. 2021 à 09:44, irland fardani <irlan128 at gmail.com> a
>> écrit :
>>> Hi, Alexandre
>>> I`m sorry, because The docker geonode that I'm using is the version
>>> 3.2.x
>>> [image: image.png]
>>> I use the latest version of geonode docker
>>> . Can anyone help me activate the ssl in geonode in port 8080, I use
>>> cert from letsencrypt?
>>> Thanks
>>> www.avg.com
>>> <#m_6399733074780055146_m_-3216880635208856271_m_4989313579081437732_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
>>> On Thu, Sep 16, 2021 at 2:14 PM Alexandre Gacon <
>>> alexandre.gacon at gmail.com> wrote:
>>>> Hi,
>>>> 2.4 is a quite old version : don't you have the possibility to work
>>>> with a more recent one (last stable is 3.2.x)?
>>>> Alexandre
>>>> Le jeu. 16 sept. 2021 à 05:49, irland fardani <irlan128 at gmail.com> a
>>>> écrit :
>>>>> Dear All,
>>>>> I install geonode 2.4.1 from docker in rhel 7,
>>>>> I try to activate the ssl in geonode in port 8080, I use cert from
>>>>> letsencrypt
>>>>> When i compose the docker without the https, it run perfectly (I
>>>>> attached my .env and docker-compose.yml),
>>>>> but when i configure to the https, it won`t start (failed)
>>>>> the error is like this
>>>>> **Trying to get STAGING certificate*
>>>>> *--server value conflicts with --staging*
>>>>> *Failed to get the certificates !**
>>>>> Can somebody give me a clue to solve this problem?
>>>>> thanks
>>>>> Irland Fardani M.T.
>>>>> +628562257785
>>>>> +6281223261345
>>>>> Program Studi Perencanaan Wilayah Kota
>>>>> <http://planologi.unisba.ac.id/>
>>>>> Fakultas Teknik <http://planologi.unisba.ac.id/>
>>>>> Universitas Islam Bandung <http://planologi.unisba.ac.id/>
>>>>> Hatur Nuhun
>>>>> www.avg.com
>>>>> <#m_6399733074780055146_m_-3216880635208856271_m_4989313579081437732_m_-2831791442631411523_m_7838770836164611147_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> Alexandre Gacon
>>> Irland Fardani M.T.
>>> +628562257785
>>> +6281223261345
>>> Program Studi Perencanaan Wilayah Kota <http://planologi.unisba.ac.id/>
>>> Hatur Nuhun
>> Alexandre Gacon
> Irland Fardani M.T.
> +628562257785
> +6281223261345
> Hatur Nuhun
Alexandre Gacon
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210916/8d4d4200/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210916/8d4d4200/attachment-0001.png>
More information about the geonode-users
