[GeoNode-users] Setting SSL in Geonode Docker Error
irland fardani irlan128 at gmail.com
Thu Sep 16 01:10:01 PDT 2021
Hi Alexandre,
I already add that,after I restart,the error is still the same
> On 16 Sep 2021, at 3.06 PM, Alexandre Gacon <alexandre.gacon at gmail.com> wrote:
> Please give a try with the following setting in your env file
> LETSENCRYPT_MODE=production
> Alexandre
>> Le jeu. 16 sept. 2021 à 10:03, irland fardani <irlan128 at gmail.com> a écrit :
>> Hi Alexandre,
>> Yes, I did , bu still got an error
>> the issue same with the thread in here
>> certbot fails when using LETSENCRYPT_MODE=staging · Issue #203 · GeoNode/geonode-project · GitHub
>> 	Virus-free. www.avg.com
>>> On Thu, Sep 16, 2021 at 2:54 PM Alexandre Gacon <alexandre.gacon at gmail.com> wrote:
>>> I never tried the staging mode for the SSL. Did you try  with the production mode instead?
>>>> Le jeu. 16 sept. 2021 à 09:44, irland fardani <irlan128 at gmail.com> a écrit :
>>>> Hi, Alexandre
>>>> I`m sorry, because The docker geonode that  I'm using is the version 3.2.x
>>>> <image.png>
>>>> I use the latest version of geonode docker
>>>> . Can anyone help me activate the ssl in geonode in port 8080, I use cert from letsencrypt?
>>>> Thanks
>>>>> On Thu, Sep 16, 2021 at 2:14 PM Alexandre Gacon <alexandre.gacon at gmail.com> wrote:
>>>>> Hi,
>>>>> 2.4 is a quite old version : don't you have the possibility to work with a more recent one (last stable is 3.2.x)?
>>>>> Alexandre
>>>>>> Le jeu. 16 sept. 2021 à 05:49, irland fardani <irlan128 at gmail.com> a écrit :
>>>>>> Dear All,
>>>>>> I install geonode 2.4.1 from docker in rhel 7,
>>>>>> I try to activate the ssl in geonode in port 8080, I use cert from letsencrypt
>>>>>> When i compose the docker without the https, it run perfectly (I attached my .env and docker-compose.yml),
>>>>>> but when i configure to the https, it won`t start (failed)
>>>>>> the error is like this
>>>>>> *Trying to get STAGING certificate
>>>>>> --server value conflicts with --staging
>>>>>> Failed to get the certificates !*
>>>>>> Can somebody give me a clue to solve this problem?
>>>>>> thanks
>>>>>> Irland Fardani M.T.
>>>>>> +628562257785
>>>>>> +6281223261345
>>>>>> Program Studi Perencanaan Wilayah Kota
>>>>>> Fakultas Teknik
>>>>>> Universitas Islam Bandung
>>>>>> Hatur Nuhun
>>>>>> _______________________________________________
>>>>>> geonode-users mailing list
>>>>>> geonode-users at lists.osgeo.org
>>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>>> Alexandre Gacon
>>>> Irland Fardani M.T.
>>>> +628562257785
>>>> +6281223261345
>>>> Fakultas Teknik
>>>> Hatur Nuhun
>>> Alexandre Gacon
>> Irland Fardani M.T.
>> +628562257785
>> +6281223261345
>> Fakultas Teknik
>> Hatur Nuhun
> Alexandre Gacon
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20210916/2994ebe2/attachment.html>
More information about the geonode-users mailing list
