[GeoNode-users] Enable INSPIRE Metadata in GeoNode and GeoServer
Rafael Sá
rafael.sa at ua.pt
Tue Aug 9 14:05:17 PDT 2022
I am using GeoNode (version 3.3.2) in a project, where one of the requirements is to be INSPIRE compliant.
I have seen that in settings.py the metadata:inspire['enabled'] is set to True. However, in the metadata details not all the fields that are required are there.
I tried to enable the INSPIRE extension in GeoServer, but it asks for a Service Metadata URL, and a Service Metadata Type (CSW GetRecord by ID request OR Online ISO 19139 Service Metadata Document). Using GeoNode, what URL should I enter?
Even if I'm using GeoServer with the INSPIRE standard, how can I display the INSPIRE metadata in the GeoNode interface? Is there any configuration I need to do, or do I have to add the fields manually (similar to the example in the documentation<https://docs.geonode.org/en/3.3.x/devel/workshops/index.html> where you add the DOI field)?
Thanks in advance,
Rafael
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20220809/463a0a3c/attachment.htm>
More information about the geonode-users
