[GeoNode-users] Option to create empty layer not showing
Alessio Fabiani alessio.fabiani at geosolutionsgroup.com
Mon Jul 18 08:22:40 PDT 2022
Hello Rafael,
you need to enable this option here "CREATE_LAYER"
https://docs.geonode.org/en/3.3.x/basic/settings/index.html#create-layer
On Mon, Jul 18, 2022 at 3:03 PM Rafael Sá <rafael.sa at ua.pt> wrote:
> Hello
> I'm using a 3.3.x version of GeoNode, together with geonode-project, and I
> don't get the option to create an empty layer. I only have the option to
> upload a layer.
> Is this functionality not in version 3.3, or do I have to enable something?
> Rafael
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions Group
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  331 6233686
https://www.geosolutionsgroup.com/
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20220718/f81a7535/attachment.htm>
More information about the geonode-users mailing list
