[GeoNode-users] decrease (map query) panel size
Alessio Fabiani
alessio.fabiani at geosolutionsgroup.com
Wed Jul 20 01:00:57 PDT 2022
Try taking a look at the _geonode_config.html template here
https://github.com/GeoNode/geonode-mapstore-client/blob/master/geonode_mapstore_client/templates/geonode-mapstore-client/_geonode_config.html
and check if there's a property allowing you to fix the panel size. It
should be related to the view that you want to tweak.
On Tue, Jul 19, 2022 at 5:10 PM Γιώργος Πούλος <gpoul2000 at hotmail.com>
wrote:
> Hello all,
> I want to decrease the size of right panel that the image shows.
> It hides a lot of map area (screenshot is in desktop). In mobile and
> tablet the problem is worst, because map area is disappearing!
> Can anybody help me? I think is pure CSS problem but I can’t understand
> how I can fix it.
> *Πούλος Γιώργος*
> *Δαβάκη 4, Λιβαδειά, 32100, *
> *Στερεά Ελλάδα*
> *t 6970115279, **mail: gpoul2000 at hotmail.com <gpoul2000 at hotmail.com>*
> P *Please consider the environment before printing this document*
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions Group
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
https://www.geosolutionsgroup.com/
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20220720/3b360ce7/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20220720/3b360ce7/attachment-0001.png>
More information about the geonode-users
