[GeoNode-users] Errors uploading shapefiles and creating empty layers
Alessio Fabiani
alessio.fabiani at geosolutionsgroup.com
Tue Jul 26 05:56:37 PDT 2022
Hello Rafael,
are you running it by using docker?
The first one could be related to the fact that the django container and
the celery one are not sharing the same "tmp" and "uploaded" folders.
The second one looks like a connection issue, try to change the connection
string into your ".env" file by using the same username and password you
have been using for the geonode_odyssey one.
On Tue, Jul 26, 2022 at 2:48 PM Rafael Sá <rafael.sa at ua.pt> wrote:
> Hello everyone,
> I have a GeoNode installation through GeoNode-project (version 3.3.x), and
> I'm having a problem uploading shapefiles. When I start the upload, I get
> an error message "The upload process cannot be completed because the
> original file is no longer available".
> When I upload GeoTIFFs there is no problem.
> In addition to this problem, when I try to create empty layers, I get this
> error: "org.postgresql.util.PSQLException: FATAL: password authentication
> failed for user "geonode_odyssey_data"
> ". I created the database according to the documentation, and had no
> problems with anything else,
> How can I fix these problems?
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions Group
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
https://www.geosolutionsgroup.com/
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20220726/69ccbe7c/attachment.htm>
More information about the geonode-users
