[GeoNode-users] Errors uploading shapefiles and creating empty layers
Rafael Sá
rafael.sa at ua.pt
Tue Jul 26 06:20:08 PDT 2022
I am not using Docker, I am running with paver. I installed according to this link: https://docs.geonode.org/en/3.3.x/devel/installation/index.html#install-geonode-project-directly-from-scratch
Regarding the second problem, I am changing the user in the ".override_dev_env" file, but the error remains with the failure to authenticate the user "geonode_odyssey_data". Should I change to another file?
De: Alessio Fabiani <alessio.fabiani at geosolutionsgroup.com>
Enviado: 26 de julho de 2022 13:56:37
Para: Rafael Sá
Cc: geonode-users at lists.osgeo.org
Assunto: Re: [GeoNode-users] Errors uploading shapefiles and creating empty layers
Hello Rafael,
are you running it by using docker?
The first one could be related to the fact that the django container and the celery one are not sharing the same "tmp" and "uploaded" folders.
The second one looks like a connection issue, try to change the connection string into your ".env" file by using the same username and password you have been using for the geonode_odyssey one.
On Tue, Jul 26, 2022 at 2:48 PM Rafael Sá <rafael.sa at ua.pt<mailto:rafael.sa at ua.pt>> wrote:
Hello everyone,
I have a GeoNode installation through GeoNode-project (version 3.3.x), and I'm having a problem uploading shapefiles. When I start the upload, I get an error message "The upload process cannot be completed because the original file is no longer available".
When I upload GeoTIFFs there is no problem.
In addition to this problem, when I try to create empty layers, I get this error: "org.postgresql.util.PSQLException: FATAL: password authentication failed for user "geonode_odyssey_data"
". I created the database according to the documentation, and had no problems with anything else,
How can I fix these problems?
geonode-users mailing list
geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geonode-users
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions Group
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
https://www.geosolutionsgroup.com/
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20220726/26d09094/attachment-0001.htm>
More information about the geonode-users
