[GeoNode-users] geonode basic installation error
Alessio Fabiani
alessio.fabiani at geosolutionsgroup.com
Fri Jul 29 04:45:09 PDT 2022
you need to upgrade the docker-compose version to latest version; see
https://stackoverflow.com/questions/49839028/how-to-upgrade-docker-compose-to-latest-version
On Fri, Jul 29, 2022 at 1:40 PM Julio Cesar Refosco <
juliorefosco at hotmail.com> wrote:
> Hi Ariel,
> Thank you for your answer. I did as you suggested and seems that worked
> for the WARNINGS, but the ERROR still there. Any ideas?
> Thanks,
> Julio
> labgeo at labgeo:~/labgeo$ sudo cp .env.sample .env
> [sudo] password for labgeo:
> labgeo at labgeo:~/labgeo$ ./docker-build.sh
> ERROR: Version in "./docker-compose.yml" is unsupported. You might be
> seeing this error because you're using the wrong Compose file version.
> Either specify a supported version (e.g "2.2" or "3.3") and place your
> service definitions under the `services` key, or omit the `version` key and
> place your service definitions at the root of the file to use version 1.
> For more on the Compose file format versions, see
> https://docs.docker.com/compose/compose-file/
> *From:* Ariel Cabezas <gerardoarielc at gmail.com>
> *Sent:* Thursday, July 28, 2022 21:19
> *To:* Julio Cesar Refosco <juliorefosco at hotmail.com>
> *Cc:* geonode-users at lists.osgeo.org <geonode-users at lists.osgeo.org>
> *Subject:* Re: [GeoNode-users] geonode basic installation error
> Hi Julio,
> for variables
> I think you have to create the file with environment variables:
> cd my_geonode
> cp .env.sample .env
> and then
> ./docker-build.sh
> Ariel
> El jue, 28 jul 2022 a las 10:06, Julio Cesar Refosco (<
> juliorefosco at hotmail.com>) escribió:
> <geonode-users at lists.osgeo.org>Hello everybody,
> Trying to install geonode using the basic installation tutorial, using
> ubuntu 20.04.4, getting this error. Any help?
> Thanks in advance.
> Julio
> WARNING: The COMPOSE_PROJECT_NAME variable is not set. Defaulting to a
> blank string.
> WARNING: The HTTPS_HOST variable is not set. Defaulting to a blank string.
> WARNING: The HTTP_HOST variable is not set. Defaulting to a blank string.
> WARNING: The HTTPS_PORT variable is not set. Defaulting to a blank string.
> WARNING: The HTTP_PORT variable is not set. Defaulting to a blank string.
> WARNING: The LETSENCRYPT_MODE variable is not set. Defaulting to a blank
> string.
> WARNING: The ADMIN_EMAIL variable is not set. Defaulting to a blank string.
> WARNING: The POSTGRESQL_MAX_CONNECTIONS variable is not set. Defaulting to
> a blank string.
> WARNING: The JENKINS_HTTP_PORT variable is not set. Defaulting to a blank
> string.
> WARNING: The JENKINS_HTTPS_PORT variable is not set. Defaulting to a blank
> string.
> <https://nam12.safelinks.protection.outlook.com/?url=https%3A%2F%2Fdocs.docker.com%2Fcompose%2Fcompose-file%2F&data=05%7C01%7C%7C5540879fde434492467008da70f80a95%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637946507876766283%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=KeP61g%2BfOfmuOl0qRiSlFUk7GnjNsRbwjLbzYtcZILQ%3D&reserved=0>
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
> <https://nam12.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgeonode-users&data=05%7C01%7C%7C5540879fde434492467008da70f80a95%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637946507876766283%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=pCFtZoaG0dPPSJJELbniWFXdGzgxi2SmCeRll62gWQ0%3D&reserved=0>
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions Group
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 331 6233686
https://www.geosolutionsgroup.com/
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20220729/8dc100f3/attachment-0001.htm>
More information about the geonode-users
