[GeoNode-users] geonode basic installation error
Julio Cesar Refosco juliorefosco at hotmail.com
Fri Jul 29 04:40:30 PDT 2022
Hi Ariel,
Thank you for your answer. I did as you suggested and seems that worked for the WARNINGS, but the ERROR still there. Any ideas?
Thanks,
Julio
labgeo at labgeo:~/labgeo$ sudo cp .env.sample .env
[sudo] password for labgeo:
labgeo at labgeo:~/labgeo$ ./docker-build.sh
ERROR: Version in "./docker-compose.yml" is unsupported. You might be seeing this error because you're using the wrong Compose file version. Either specify a supported version (e.g "2.2" or "3.3") and place your service definitions under the `services` key, or omit the `version` key and place your service definitions at the root of the file to use version 1.
For more on the Compose file format versions, see https://docs.docker.com/compose/compose-file/
Sent: Thursday, July 28, 2022 21:19
To: Julio Cesar Refosco <juliorefosco at hotmail.com>
Cc: geonode-users at lists.osgeo.org <geonode-users at lists.osgeo.org>
Subject: Re: [GeoNode-users] geonode basic installation error
Hi Julio,
for variables
I think you have to create the file with environment variables:
cd my_geonode
cp .env.sample .env
and then
./docker-build.sh
Ariel
El jue, 28 jul 2022 a las 10:06, Julio Cesar Refosco (<juliorefosco at hotmail.com<mailto:juliorefosco at hotmail.com>>) escribió:
<mailto:geonode-users at lists.osgeo.org>Hello everybody,
Trying to install geonode using the basic installation tutorial, using ubuntu 20.04.4, getting this error. Any help?
Thanks in advance.
Julio
WARNING: The COMPOSE_PROJECT_NAME variable is not set. Defaulting to a blank string.
WARNING: The HTTPS_HOST variable is not set. Defaulting to a blank string.
WARNING: The HTTP_HOST variable is not set. Defaulting to a blank string.
WARNING: The HTTPS_PORT variable is not set. Defaulting to a blank string.
WARNING: The HTTP_PORT variable is not set. Defaulting to a blank string.
WARNING: The LETSENCRYPT_MODE variable is not set. Defaulting to a blank string.
WARNING: The ADMIN_EMAIL variable is not set. Defaulting to a blank string.
WARNING: The POSTGRESQL_MAX_CONNECTIONS variable is not set. Defaulting to a blank string.
WARNING: The JENKINS_HTTP_PORT variable is not set. Defaulting to a blank string.
WARNING: The JENKINS_HTTPS_PORT variable is not set. Defaulting to a blank string.
For more on the Compose file format versions, see https://docs.docker.com/compose/compose-file/<https://nam12.safelinks.protection.outlook.com/?url=https%3A%2F%2Fdocs.docker.com%2Fcompose%2Fcompose-file%2F&data=05%7C01%7C%7C5540879fde434492467008da70f80a95%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637946507876766283%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=KeP61g%2BfOfmuOl0qRiSlFUk7GnjNsRbwjLbzYtcZILQ%3D&reserved=0>
geonode-users mailing list
geonode-users at lists.osgeo.org<mailto:geonode-users at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/geonode-users<https://nam12.safelinks.protection.outlook.com/?url=https%3A%2F%2Flists.osgeo.org%2Fmailman%2Flistinfo%2Fgeonode-users&data=05%7C01%7C%7C5540879fde434492467008da70f80a95%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637946507876766283%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=pCFtZoaG0dPPSJJELbniWFXdGzgxi2SmCeRll62gWQ0%3D&reserved=0>
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20220729/d34f1e85/attachment.htm>
More information about the geonode-users mailing list
