[GeoNode-users] geonode basic installation error
Ariel Cabezas
gerardoarielc at gmail.com
Thu Jul 28 17:19:34 PDT 2022
Hi Julio,
for variables
I think you have to create the file with environment variables:
cd my_geonode
cp .env.sample .env
and then
./docker-build.sh
Ariel
El jue, 28 jul 2022 a las 10:06, Julio Cesar Refosco (<
juliorefosco at hotmail.com>) escribió:
> <geonode-users at lists.osgeo.org>Hello everybody,
> Trying to install geonode using the basic installation tutorial, using
> ubuntu 20.04.4, getting this error. Any help?
> Thanks in advance.
> Julio
> WARNING: The COMPOSE_PROJECT_NAME variable is not set. Defaulting to a
> blank string.
> WARNING: The HTTPS_HOST variable is not set. Defaulting to a blank string.
> WARNING: The HTTP_HOST variable is not set. Defaulting to a blank string.
> WARNING: The HTTPS_PORT variable is not set. Defaulting to a blank string.
> WARNING: The HTTP_PORT variable is not set. Defaulting to a blank string.
> WARNING: The LETSENCRYPT_MODE variable is not set. Defaulting to a blank
> string.
> WARNING: The ADMIN_EMAIL variable is not set. Defaulting to a blank string.
> WARNING: The POSTGRESQL_MAX_CONNECTIONS variable is not set. Defaulting to
> a blank string.
> WARNING: The JENKINS_HTTP_PORT variable is not set. Defaulting to a blank
> string.
> WARNING: The JENKINS_HTTPS_PORT variable is not set. Defaulting to a blank
> string.
> ERROR: Version in "./docker-compose.yml" is unsupported. You might be
> seeing this error because you're using the wrong Compose file version.
> Either specify a supported version (e.g "2.2" or "3.3") and place your
> service definitions under the `services` key, or omit the `version` key and
> place your service definitions at the root of the file to use version 1.
> For more on the Compose file format versions, see
> https://docs.docker.com/compose/compose-file/
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20220728/9501b0b2/attachment.htm>
More information about the geonode-users
