[GeoNode-users] geonode basic installation error
Julio Cesar Refosco juliorefosco at hotmail.com
Thu Jul 28 06:05:47 PDT 2022
<mailto:geonode-users at lists.osgeo.org>Hello everybody,
Trying to install geonode using the basic installation tutorial, using ubuntu 20.04.4, getting this error. Any help?
Thanks in advance.
Julio
WARNING: The COMPOSE_PROJECT_NAME variable is not set. Defaulting to a blank string.
WARNING: The HTTPS_HOST variable is not set. Defaulting to a blank string.
WARNING: The HTTP_HOST variable is not set. Defaulting to a blank string.
WARNING: The HTTPS_PORT variable is not set. Defaulting to a blank string.
WARNING: The HTTP_PORT variable is not set. Defaulting to a blank string.
WARNING: The LETSENCRYPT_MODE variable is not set. Defaulting to a blank string.
WARNING: The ADMIN_EMAIL variable is not set. Defaulting to a blank string.
WARNING: The POSTGRESQL_MAX_CONNECTIONS variable is not set. Defaulting to a blank string.
WARNING: The JENKINS_HTTP_PORT variable is not set. Defaulting to a blank string.
WARNING: The JENKINS_HTTPS_PORT variable is not set. Defaulting to a blank string.
ERROR: Version in "./docker-compose.yml" is unsupported. You might be seeing this error because you're using the wrong Compose file version. Either specify a supported version (e.g "2.2" or "3.3") and place your service definitions under the `services` key, or omit the `version` key and place your service definitions at the root of the file to use version 1.
For more on the Compose file format versions, see https://docs.docker.com/compose/compose-file/
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20220728/e1ea339f/attachment.htm>
More information about the geonode-users mailing list
