[GeoNode-users] Develop with docker container
Pierre HARDY
pierre.hardy5 at gmail.com
Wed Mar 2 05:43:53 PST 2022
Geonode version:
*3.3.1 (downloaded from release on github)*
OS: Centos 7
Following your recommendation, I have done the following:
- *Trial no. 1*
*docker-compose --project-name geonode -f docker-compose.yml -f
.devcontainer/docker-compose.yml up*
Which returned this:
*django4geonode | No idea what 'devrequirements' is!*
*django4geonode exited with code *
- *Trial no. 2*
.devcontainer/docker-compose.yml build*
My .env file is the default one, I juste replaced "localhost" by my domain
name.
I am working on remote server because my local machine is under windows OS
and I have issues at running the project locally (even inside docker) due
to line return encoding (LF/CRLF)
Everything is working fine when I run docker-compose up (I tested file
upload).
Le mer. 2 mars 2022 à 12:22, Alessio Fabiani <
alessio.fabiani at geosolutionsgroup.com> a écrit :
> Which version?
> If you start the container by using the following command
> docker-compose --project-name geonode -f docker-compose.yml -f .devcontainer/docker-compose.yml up
> that should override the django container default command so things don't
> shut down after the process ends (see here
> <https://github.com/GeoNode/geonode/blob/master/.devcontainer/docker-compose.yml#L50>
> for more details).
> This won't start the uwsgi command on the 8000 port too.
> On Wed, Mar 2, 2022 at 12:05 PM Pierre HARDY <pierre.hardy5 at gmail.com>
> wrote:
>> Hello,
>> I following the instruction stated here: URL
>> <https://docs.geonode.org/en/3.3.x/devel/docker/index.html#start-to-develop-with-docker>
>> Using vscode extension, I can start a terminal session inside the
>> django4geonode container.
>> However, when I try to run the container on port 8000 it seems that the *uwsgi
>> *service is already running:
>> [image: image.png]
>> I can run the server on port 8800. However I would like to run it on the
>> port 8000 in order to have access to it remotely (it will be then served by
>> NGINX).
>> It there a way to do start dev server on port 8000 ?
>> Thanks !
>> Pierre HARDY
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts!
> Visit http://bit.ly/gs-services-us for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions Group
> phone: +39 0584 962313
> fax: +39 0584 1660272
> mob: +39 333 8128928
> https://www.geosolutionsgroup.com/
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
Pierre HARDY
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20220302/b8af7b42/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20220302/b8af7b42/attachment-0001.png>
More information about the geonode-users
