[GeoNode-users] Develop with docker container
Florian Hoedt
florian.hoedt at thuenen.de
Wed Mar 2 05:49:09 PST 2022
Hi Pierre,
I have done some changes to get a docker dev env running with PyCharm (commercial ed.). You can see my changes and comment here:
[ https://github.com/GeoNode/geonode/pull/8177#issuecomment-954673780 | https://github.com/GeoNode/geonode/pull/8177#issuecomment-954673780 ]
[ https://github.com/gannebamm/geonode/commit/50881f66204c34ef26538bc3015b99a1e5d9947f | https://github.com/gannebamm/geonode/commit/50881f66204c34ef26538bc3015b99a1e5d9947f ]
maybe that helps
yours,
Florian
MSc Florian Hoedt
Head Research Data Management | OpenData Representative
Thünen Institute, Centre for Information Management
Bundesallee 44
38116 Braunschweig
Tel: +49 531 596-1428 | Mobile: +49 162 92 50 275
Fax: +49 531 596-1499
Mail: florian.hoedt at thuenen.de
Web: www.thuenen.de
The Johann Heinrich von Thünen Institute, Federal Research Institute for Rural Areas, Forestry and Fisheries – Thünen Institute in brief – consists of 15 specialized institutes with socioeconomic, ecological and technological expertise. The Thünen Institute conducts research and policy advice related to rural areas, agriculture, forests and fisheries.
Von: "Pierre HARDY" <pierre.hardy5 at gmail.com>
An: "Alessio Fabiani" <alessio.fabiani at geosolutionsgroup.com>
CC: "geonode-users" <geonode-users at lists.osgeo.org>
Gesendet: Mittwoch, 2. März 2022 14:43:53
Betreff: Re: [GeoNode-users] Develop with docker container
Geonode version: 3.3.1 (downloaded from release on github)
OS: Centos 7
Following your recommendation, I have done the following:
* Trial no. 1
docker-compose --project-name geonode -f docker-compose.yml -f .devcontainer/docker-compose.yml up
Which returned this:
django4geonode | No idea what 'devrequirements' is!
django4geonode exited with code
* Trial no. 2
docker-compose --project-name geonode -f docker-compose.yml -f .devcontainer/docker-compose.yml build
My .env file is the default one, I juste replaced "localhost" by my domain name.
I am working on remote server because my local machine is under windows OS and I have issues at running the project locally (even inside docker) due to line return encoding (LF/CRLF)
Everything is working fine when I run docker-compose up (I tested file upload).
Le mer. 2 mars 2022 à 12:22, Alessio Fabiani < [ mailto:alessio.fabiani at geosolutionsgroup.com | alessio.fabiani at geosolutionsgroup.com ] > a écrit :
Which version?
If you start the container by using the following command
that should override the django container default command so things don't shut down after the process ends (see [ https://github.com/GeoNode/geonode/blob/master/.devcontainer/docker-compose.yml#L50 | here ] for more details).
This won't start the uwsgi command on the 8000 port too.
On Wed, Mar 2, 2022 at 12:05 PM Pierre HARDY < [ mailto:pierre.hardy5 at gmail.com | pierre.hardy5 at gmail.com ] > wrote:
BQ_BEGIN
Hello,
I following the instruction stated here: [ https://docs.geonode.org/en/3.3.x/devel/docker/index.html#start-to-develop-with-docker | URL ]
Using vscode extension, I can start a terminal session inside the django4geonode container.
However, when I try to run the container on port 8000 it seems that the uwsgi service is already running:
I can run the server on port 8800. However I would like to run it on the port 8000 in order to have access to it remotely (it will be then served by NGINX).
It there a way to do start dev server on port 8000 ?
Thanks !
Pierre HARDY
geonode-users mailing list
[ mailto:geonode-users at lists.osgeo.org | geonode-users at lists.osgeo.org ]
[ https://lists.osgeo.org/mailman/listinfo/geonode-users | https://lists.osgeo.org/mailman/listinfo/geonode-users ]
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts!
Visit [ http://bit.ly/gs-services-us | http://bit.ly/gs-services-us ] for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions Group
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39 333 8128928
[ https://www.geosolutionsgroup.com/ | https://www.geosolutionsgroup.com/ ]
[ http://twitter.com/geosolutions_it | http://twitter.com/geosolutions_it ]
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si precisa che ogni circostanza inerente alla presente email (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is addressed and may contain information that is privileged, confidential or otherwise protected from disclosure. We remind that - as provided by European Regulation 2016/679 “GDPR” - copying, dissemination or use of this e-mail or the information herein by anyone other than the intended recipient is prohibited. If you have received this email by mistake, please notify us immediately by telephone or e-mail.
BQ_END
Pierre HARDY
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20220302/07dec6ec/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20220302/07dec6ec/attachment-0001.png>
More information about the geonode-users
