[GeoNode-users] No delete ? No upload ?
Brian Wilson brian at wildsong.biz
Fri May 13 09:07:02 PDT 2022
This should be an easy one for you...
I am using https://github.com/GeoNode/geonode-project.git
It's branch 3.2.x
Before starting I tried out the master.demo.geonode.org, registered,
uploaded a layer, visualized it in a map and then deleted the layer.
I managed to stumble through setting up the Docker geonode project, and to
create a new layer from scratch. I set up on a machine with Internet access
and gave it a domain name and set up .env so it was able to get certs via
Let's Encrypt.
The test machine has 32GB of RAM and 4 cores and 200 or so gigs of space.
I have two major problems with it,
1. There does not appear to be any delete button. There is no DELETE? :-)
Clearly I have done something wrong. :-)  Perhaps I just have not searched
hard enough.
2. Uploads fail. I tested a small shapefile on the demo site and it worked.
On my dockerized set up I tried uploading both the zip and unzipped files.
The error message screams at me that there is a filesystem mount problem
but I don't know which docker container to look at.
"/mnt/volumes/statics"....
Unexpected error! - Unknwon Error Code. Contact the system administrator
for more information regarding this error message. Additional info: [Client
Error: Bad Request
Unexpected exception [Errno 2] No such file or directory:
'/mnt/volumes/statics/static/tmpz6rofbjd']
Happy Friday 13 ~~
Brian Wilson
tel:707-827-0001
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20220513/76af0a50/attachment.htm>
More information about the geonode-users mailing list
