[GeoNode-users] Can not login to GeoServer
Ramesh De Silva desilvarami at gmail.com
Mon Oct 10 05:27:10 PDT 2022
Dear Alessio,
Thank you for your email. I have replaced all the "localhost" entries to my
IP in .env. Please see the image below. Are there any other places I need
to update?
[image: image.png]
Thank you.
Kind regards
Ramesh
On Mon, Oct 10, 2022 at 4:38 PM Alessio Fabiani <
alessio.fabiani at geosolutionsgroup.com> wrote:
> The locations of GeoServer are clearly wrong on the .env file.
> They still refer to "localhost"
> On Mon, Oct 10, 2022 at 12:30 PM Ramesh De Silva <desilvarami at gmail.com>
> wrote:
>> Hi,
>> I have installed a GeoNode (4.X) using the GeoNode Master Advanced Core
>> Docker guide in a Ubuntu 22.04 Server VM. (
>> https://docs.geonode.org/en/master/install/advanced/core/index.html#docker
>> All the installation steps were successfully executed and all containers
>> loaded healthy. I have updated the IP in .env.
>> [image: image.png]
>> I can access GeoNode Home Page, Django Administration Page and GeoServer
>> Home Page from the IP Address. But when I try to login to GeoServer, for
>> some reason it redirects to localhost and fails (
>> http://localhost/geoserver/j_spring_security_check). Please provide any
>> possible help.
>> [image: image.png]
>> [image: image.png]
>> Thank you.
>> Kind regards
>> Ramesh
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts!
> Visit http://bit.ly/gs-services-us for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions Group
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39  331 6233686
> https://www.geosolutionsgroup.com/
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221010/7198cf69/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221010/7198cf69/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221010/7198cf69/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221010/7198cf69/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221010/7198cf69/attachment-0007.png>
More information about the geonode-users mailing list
