[GeoNode-users] Can not login to GeoServer
Ramesh De Silva
desilvarami at gmail.com
Mon Oct 10 20:53:16 PDT 2022
Dear Alessio,
Further more details about the situation. I could successfully upload a
dataset via GeoNode.
[image: image.png]
Then I checked the layer preview from GeoServer. Interestingly, when I
clicked on the "Layer Preview" link at the GeoServer Home page, I was
authenticated as I have already logged into GeoNode. Then I could
navigate to all GeoServer menus.
[image: image.png]
But when I clicked on the OpenLayers link at layer preview, it refers to
localhost again.
[image: image.png]
I have updated this IP in Django OAuth and restarted the containers. But
this issue persists.
[image: image.png]
Appreciate your help.
Kind regards
Ramesh
On Mon, Oct 10, 2022 at 6:13 PM Alessio Fabiani <
alessio.fabiani at geosolutionsgroup.com> wrote:
> Nope
> On Mon, Oct 10, 2022 at 2:23 PM Ramesh De Silva <desilvarami at gmail.com>
> wrote:
>> Dear Alessio,
>> Thank you for your email. I have replaced all the "localhost" entries to
>> my IP in .env. Please see the image below. Are there any other places I
>> need to update?
>> [image: image.png]
>> Thank you.
>> Kind regards
>> Ramesh
>> On Mon, Oct 10, 2022 at 4:38 PM Alessio Fabiani <
>>> The locations of GeoServer are clearly wrong on the .env file.
>>> They still refer to "localhost"
>>> On Mon, Oct 10, 2022 at 12:30 PM Ramesh De Silva <desilvarami at gmail.com>
>>> wrote:
>>>> Hi,
>>>> I have installed a GeoNode (4.X) using the GeoNode Master Advanced Core
>>>> Docker guide in a Ubuntu 22.04 Server VM. (
>>>> https://docs.geonode.org/en/master/install/advanced/core/index.html#docker
>>>> All the installation steps were successfully executed and all
>>>> containers loaded healthy. I have updated the IP in .env.
>>>> [image: image.png]
>>>> I can access GeoNode Home Page, Django Administration Page and
>>>> GeoServer Home Page from the IP Address. But when I try to login to
>>>> GeoServer, for some reason it redirects to localhost and fails (
>>>> http://localhost/geoserver/j_spring_security_check). Please provide
>>>> any possible help.
>>>> [image: image.png]
>>>> [image: image.png]
>>>> Thank you.
>>>> Kind regards
>>>> Ramesh
>>>> _______________________________________________
>>>> geonode-users mailing list
>>>> geonode-users at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>> Regards,
>>> Alessio Fabiani
>>> GeoServer Professional Services from the experts!
>>> Visit http://bit.ly/gs-services-us for more information.
>>> Ing. Alessio Fabiani
>>> @alfa7691
>>> Founder/Technical Lead
>>> GeoSolutions Group
>>> phone: +39 0584 962313
>>> fax: +39 0584 1660272
>>> mob: +39 331 6233686
>>> https://www.geosolutionsgroup.com/
>>> http://twitter.com/geosolutions_it
>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>> precisa che ogni circostanza inerente alla presente email (il suo
>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>> This email is intended only for the person or entity to which it is
>>> addressed and may contain information that is privileged, confidential or
>>> otherwise protected from disclosure. We remind that - as provided by
>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>> e-mail or the information herein by anyone other than the intended
>>> recipient is prohibited. If you have received this email by mistake, please
>>> notify us immediately by telephone or e-mail.
> Regards,
> Alessio Fabiani
> @alfa7691
> GeoSolutions Group
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221011/3cc99f02/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221011/3cc99f02/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221011/3cc99f02/attachment-0009.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221011/3cc99f02/attachment-0010.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221011/3cc99f02/attachment-0011.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221011/3cc99f02/attachment-0012.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221011/3cc99f02/attachment-0013.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221011/3cc99f02/attachment-0014.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221011/3cc99f02/attachment-0015.png>
More information about the geonode-users
