[GeoNode-users] Can not login to GeoServer
Ramesh De Silva
desilvarami at gmail.com
Mon Oct 10 21:17:47 PDT 2022
Dear Alessio,
Good news. As explained in my previous email, I could access the GeoServer
via Layer Preview link. Hence, I got a chance to update the "Proxy Base
URL" at GeoServer Global Settings. After that everything was OK.
Kind regards
Ramesh
On Tue, Oct 11, 2022 at 9:23 AM Ramesh De Silva <desilvarami at gmail.com>
wrote:
> Dear Alessio,
> Further more details about the situation. I could successfully upload a
> dataset via GeoNode.
> [image: image.png]
> Then I checked the layer preview from GeoServer. Interestingly, when I
> clicked on the "Layer Preview" link at the GeoServer Home page, I was
> authenticated as I have already logged into GeoNode. Then I could
> navigate to all GeoServer menus.
> [image: image.png]
> But when I clicked on the OpenLayers link at layer preview, it refers to
> localhost again.
> [image: image.png]
> I have updated this IP in Django OAuth and restarted the containers. But
> this issue persists.
> [image: image.png]
> Appreciate your help.
> Kind regards
> Ramesh
> On Mon, Oct 10, 2022 at 6:13 PM Alessio Fabiani <
> alessio.fabiani at geosolutionsgroup.com> wrote:
>> Nope
>> On Mon, Oct 10, 2022 at 2:23 PM Ramesh De Silva <desilvarami at gmail.com>
>> wrote:
>>> Dear Alessio,
>>> Thank you for your email. I have replaced all the "localhost" entries to
>>> my IP in .env. Please see the image below. Are there any other places I
>>> need to update?
>>> [image: image.png]
>>> Thank you.
>>> Kind regards
>>> Ramesh
>>> On Mon, Oct 10, 2022 at 4:38 PM Alessio Fabiani <
>>>> The locations of GeoServer are clearly wrong on the .env file.
>>>> They still refer to "localhost"
>>>> On Mon, Oct 10, 2022 at 12:30 PM Ramesh De Silva <desilvarami at gmail.com>
>>>> wrote:
>>>>> Hi,
>>>>> I have installed a GeoNode (4.X) using the GeoNode Master Advanced
>>>>> Core Docker guide in a Ubuntu 22.04 Server VM. (
>>>>> https://docs.geonode.org/en/master/install/advanced/core/index.html#docker
>>>>> All the installation steps were successfully executed and all
>>>>> containers loaded healthy. I have updated the IP in .env.
>>>>> [image: image.png]
>>>>> I can access GeoNode Home Page, Django Administration Page and
>>>>> GeoServer Home Page from the IP Address. But when I try to login to
>>>>> GeoServer, for some reason it redirects to localhost and fails (
>>>>> http://localhost/geoserver/j_spring_security_check). Please provide
>>>>> any possible help.
>>>>> [image: image.png]
>>>>> [image: image.png]
>>>>> Thank you.
>>>>> Kind regards
>>>>> Ramesh
>>>>> _______________________________________________
>>>>> geonode-users mailing list
>>>>> geonode-users at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>>>> Regards,
>>>> Alessio Fabiani
>>>> GeoServer Professional Services from the experts!
>>>> Visit http://bit.ly/gs-services-us for more information.
>>>> Ing. Alessio Fabiani
>>>> @alfa7691
>>>> Founder/Technical Lead
>>>> GeoSolutions Group
>>>> phone: +39 0584 962313
>>>> fax: +39 0584 1660272
>>>> mob: +39 331 6233686
>>>> https://www.geosolutionsgroup.com/
>>>> http://twitter.com/geosolutions_it
>>>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>>>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>>>> precisa che ogni circostanza inerente alla presente email (il suo
>>>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>>>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>>>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>>>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>>>> This email is intended only for the person or entity to which it is
>>>> addressed and may contain information that is privileged, confidential or
>>>> otherwise protected from disclosure. We remind that - as provided by
>>>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>>>> e-mail or the information herein by anyone other than the intended
>>>> recipient is prohibited. If you have received this email by mistake, please
>>>> notify us immediately by telephone or e-mail.
>> Regards,
>> Alessio Fabiani
>> @alfa7691
>> GeoSolutions Group
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221011/32860528/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221011/32860528/attachment-0008.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221011/32860528/attachment-0009.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221011/32860528/attachment-0010.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221011/32860528/attachment-0011.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221011/32860528/attachment-0012.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221011/32860528/attachment-0013.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221011/32860528/attachment-0014.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20221011/32860528/attachment-0015.png>
More information about the geonode-users
