[GeoNode-users] 502 Bad Gateway
Ramesh De Silva desilvarami at gmail.com
Wed Sep 28 21:47:56 PDT 2022
Dear Alessio,
Thank you for your reply. Can you please provide me some guidance to
resolve this error, as I don't have any idea of the same.
Kind regards
Ramesh
On Wed, Sep 28, 2022 at 7:30 PM Alessio Fabiani <
alessio.fabiani at geosolutionsgroup.com> wrote:
> Hi Ramesh,
> from the logs it looks like a "migration" is missing. In particular the
> "monitoring" one.
> On Wed, Sep 28, 2022 at 6:39 AM Ramesh De Silva <desilvarami at gmail.com>
> wrote:
>> Hi,
>> I've installed GeoNode 4.X on Ubuntu 22.04 Server OS. The system is
>> installed in a virtual private server. I used the GeoNode Core Advanced
>> Installation Guide. All the commands were successfully executed. All
>> services such as tomcat9, ngnix, uwsgi, postgres are active. I have already
>> configured the public IP in geonode.ini etc. But when I try to access the
>> GeoNode, I get *502 Bad Gateway* error. I can access the GeoServer from
>> the configured IP.
>> When I check the error logs, I see the following error (*ngnix
>> errror.log*).
>> "*2022/09/28 04:20:44 [error] 42102#42102: *99 connect() failed (111:
>> Connection refused) while connecting to upstream, client: 188.185.122.120,
>> server: 188.185.9.236, request: "GET / HTTP/1.1", upstream:
>> "uwsgi://127.0.0.1:8000 <http://127.0.0.1:8000>", host: "188.185.9.236*"
>> *ngnix* *access.log*
>> "*188.185.122.120 - - [28/Sep/2022:04:23:16 +0000] "GET / HTTP/1.1" 502
>> 166 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:105.0) Gecko/20100101
>> Firefox/105.0"*
>> *188.185.122.120 - - [28/Sep/2022:04:23:30 +0000] "GET /geoserver/web/
>> HTTP/1.1" 200 2589 "http://188.185.9.236/geoserver/index.html
>> <http://188.185.9.236/geoserver/index.html>" "Mozilla/5.0 (Windows NT 10.0;
>> Win64; x64; rv:105.0) Gecko/20100101 Firefox/105.0*"
>> */opt/data/logs/geonode.log*
>> "  *File
>> "/home/ubuntu/.virtualenvs/geonode/lib/python3.8/site-packages/django/db/backends/utils.py",
>> line 84, in _execute*
>> *    return self.cursor.execute(sql,
>> params)django.db.utils.ProgrammingError: relation "monitoring_host" does
>> not existLINE 1: ...oring_host"."ip", "monitoring_host"."active" FROM
>> "monitorin...  *
>> *unable to load app 0 (mountpoint='') (callable not found or import
>> error)*** no app loaded. GAME OVER ****"
>> This IP is not open to outside yet.
>> Kindly help resolve this issue.
>> Thank you.
>> Kind Regards
>> Ramesh
>> geonode-users mailing list
>> geonode-users at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/geonode-users
> Regards,
> Alessio Fabiani
> GeoServer Professional Services from the experts!
> Visit http://bit.ly/gs-services-us for more information.
> Ing. Alessio Fabiani
> @alfa7691
> Founder/Technical Lead
> GeoSolutions Group
> phone: +39 0584 962313
> fax:     +39 0584 1660272
> mob:   +39  331 6233686
> https://www.geosolutionsgroup.com/
> http://twitter.com/geosolutions_it
> Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
> 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
> precisa che ogni circostanza inerente alla presente email (il suo
> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
> This email is intended only for the person or entity to which it is
> addressed and may contain information that is privileged, confidential or
> otherwise protected from disclosure. We remind that - as provided by
> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
> e-mail or the information herein by anyone other than the intended
> recipient is prohibited. If you have received this email by mistake, please
> notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20220929/46215f75/attachment.htm>
More information about the geonode-users mailing list
