[GeoNode-users] 502 Bad Gateway
Alessio Fabiani
alessio.fabiani at geosolutionsgroup.com
Thu Sep 29 00:59:14 PDT 2022
Hi Ramesh,
make sure the "MONITORING_ENABLED" property is set to True on your
settings/environment and then run the management commands "makemigrations"
and "migrate".
Check the official GeoNode documentation for more information on how to
use/run them.
https://docs.geonode.org/en/master/
On Thu, Sep 29, 2022 at 6:48 AM Ramesh De Silva <desilvarami at gmail.com>
wrote:
> Dear Alessio,
> Thank you for your reply. Can you please provide me some guidance to
> resolve this error, as I don't have any idea of the same.
> Kind regards
> Ramesh
> On Wed, Sep 28, 2022 at 7:30 PM Alessio Fabiani <
> alessio.fabiani at geosolutionsgroup.com> wrote:
>> Hi Ramesh,
>> from the logs it looks like a "migration" is missing. In particular the
>> "monitoring" one.
>> On Wed, Sep 28, 2022 at 6:39 AM Ramesh De Silva <desilvarami at gmail.com>
>> wrote:
>>> Hi,
>>> I've installed GeoNode 4.X on Ubuntu 22.04 Server OS. The system is
>>> installed in a virtual private server. I used the GeoNode Core Advanced
>>> Installation Guide. All the commands were successfully executed. All
>>> services such as tomcat9, ngnix, uwsgi, postgres are active. I have already
>>> configured the public IP in geonode.ini etc. But when I try to access the
>>> GeoNode, I get *502 Bad Gateway* error. I can access the GeoServer from
>>> the configured IP.
>>> When I check the error logs, I see the following error (*ngnix
>>> errror.log*).
>>> "*2022/09/28 04:20:44 [error] 42102#42102: *99 connect() failed (111:
>>> Connection refused) while connecting to upstream, client: 188.185.122.120,
>>> server: 188.185.9.236, request: "GET / HTTP/1.1", upstream:
>>> "uwsgi://127.0.0.1:8000 <http://127.0.0.1:8000>", host: "188.185.9.236*"
>>> *ngnix* *access.log*
>>> "*188.185.122.120 - - [28/Sep/2022:04:23:16 +0000] "GET / HTTP/1.1" 502
>>> 166 "-" "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:105.0) Gecko/20100101
>>> Firefox/105.0"*
>>> *188.185.122.120 - - [28/Sep/2022:04:23:30 +0000] "GET /geoserver/web/
>>> HTTP/1.1" 200 2589 "http://188.185.9.236/geoserver/index.html
>>> <http://188.185.9.236/geoserver/index.html>" "Mozilla/5.0 (Windows NT 10.0;
>>> Win64; x64; rv:105.0) Gecko/20100101 Firefox/105.0*"
>>> */opt/data/logs/geonode.log*
>>> " *File
>>> "/home/ubuntu/.virtualenvs/geonode/lib/python3.8/site-packages/django/db/backends/utils.py",
>>> line 84, in _execute*
>>> * return self.cursor.execute(sql,
>>> params)django.db.utils.ProgrammingError: relation "monitoring_host" does
>>> not existLINE 1: ...oring_host"."ip", "monitoring_host"."active" FROM
>>> "monitorin... *
>>> *unable to load app 0 (mountpoint='') (callable not found or import
>>> error)*** no app loaded. GAME OVER ****"
>>> This IP is not open to outside yet.
>>> Kindly help resolve this issue.
>>> Thank you.
>>> Kind Regards
>>> Ramesh
>>> geonode-users mailing list
>>> geonode-users at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/geonode-users
>> Regards,
>> Alessio Fabiani
>> GeoServer Professional Services from the experts!
>> Visit http://bit.ly/gs-services-us for more information.
>> Ing. Alessio Fabiani
>> @alfa7691
>> Founder/Technical Lead
>> GeoSolutions Group
>> phone: +39 0584 962313
>> fax: +39 0584 1660272
>> mob: +39 331 6233686
>> https://www.geosolutionsgroup.com/
>> http://twitter.com/geosolutions_it
>> Con riferimento alla normativa sul trattamento dei dati personali (Reg.
>> UE 2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
>> precisa che ogni circostanza inerente alla presente email (il suo
>> contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
>> riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
>> messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
>> operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
>> This email is intended only for the person or entity to which it is
>> addressed and may contain information that is privileged, confidential or
>> otherwise protected from disclosure. We remind that - as provided by
>> European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
>> e-mail or the information herein by anyone other than the intended
>> recipient is prohibited. If you have received this email by mistake, please
>> notify us immediately by telephone or e-mail.
Regards,
Alessio Fabiani
@alfa7691
GeoSolutions Group
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20220929/a3b77cde/attachment-0001.htm>
More information about the geonode-users
