[GeoNode-users] Raspberry Pi 4 8gb arm64
    Alessio Fabiani
    alessio.fabiani at geosolutionsgroup.com
    Fri May  5 07:39:34 PDT 2023
There's an old geonode-project branch that allow you to build on an arm64
architecture
https://github.com/Geonode/geonode-project/tree/master-arm64
On Fri, May 5, 2023 at 11:20 AM Jan Willem van der Lichte <
jwgvanderlichte at gmail.com> wrote:
> Hi,
> I was trying to install Geonode on a raspbery pi 4, with 8gb of memory
> After installing ubuntu 22.04 on it , I wanted to install geonode using
> docker.
> Here comes the problem. It didn't work, for the database I needed the
> platform arm64 version to install it.
> "no matching manifest for linux/arm64 in the manifest entries"
> I ended up with a discussion I found (
> https://github.com/postgis/docker-postgis/issues/216) .
> Also I found that kartoza has multiple version of the docker for postgis
> with postgres >14
> So now the hard part, can I change the official geonode/postgis by a
> kartoza one
> and how to do so?
> Just wondering,
> has anyone any experience on this issue
> Or are there any plans in the official release to upgrade the database to
> a version which does support arm64?
> thanks,
> Jan WIllem
> geonode-users mailing list
> geonode-users at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/geonode-users
Regards,
Alessio Fabiani
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
GeoSolutions Group
phone: +39 0584 962313
fax:     +39 0584 1660272
mob:   +39  331 6233686
https://www.geosolutionsgroup.com/
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20230505/a34bdc71/attachment.htm>
More information about the geonode-users
