[GeoNode-users] Failed Upload Dataset
Giovanni Allegri
giovanni.allegri at geosolutionsgroup.com
Mon Aug 26 03:24:00 PDT 2024
>From logs, I suspect the upload is routed to the internal GeoNode proxy,
which is unexpected.
I think you have something wrong with your configs. Double-check the
settings related to SITEURL.
Is it a Docker?
Giovanni
On Mon, Aug 26, 2024 at 9:23 AM Abdul Hamid via geonode-users <
geonode-users at lists.osgeo.org> wrote:
> Hi all
> I tried to upload ESRI data into geonode (using geonode 4.2.5) but after
> selecting the file and clicking upload there was a failure, as shown in the
> image below
> [image: Geonode]
> this is log taken from /var/log/geonode.log
> Internal Server Error: /proxy/
> Traceback (most recent call last):
> File
> "/home/admina/.virtualenvs/geonode/lib/python3.10/site-packages/django/core/handlers/exception.py",
> line 47, in inner
> response = get_response(request)
> File
> "/home/adminkominfo/.virtualenvs/geonode/lib/python3.10/site-packages/django/core/handlers/base.py",
> line 181, in _get_response
> response = wrapped_callback(request, *callback_args, **callback_kwargs)
> File
> "/home/admina/.virtualenvs/geonode/lib/python3.10/site-packages/django/utils/decorators.py",
> line 130, in _wrapped_view
> response = view_func(request, *args, **kwargs)
> File "/opt/geonode/./geonode/proxy/views.py", line 185, in proxy
> _data = request.body.decode("utf-8")
> File
> "/home/admina/.virtualenvs/geonode/lib/python3.10/site-packages/django/http/request.py",
> line 330, in body
> raise RawPostDataException("You cannot access body after reading from
> request's data stream")
> django.http.request.RawPostDataException: You cannot access body after
> reading from request's data stream
> Thank You
> Br
> Hamid
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information.
Dott. Giovanni Allegri
Technical Lead / Project Manager
GeoSolutions Group
phone: +39 0584 962313
cell: +39 345 2815774
fax: +39 0584 1660272
https://www.geosolutionsgroup.com/
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20240826/754860b9/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20240826/754860b9/attachment-0001.png>
More information about the geonode-users
