[GeoNode-users] Failed Upload Dataset
Abdul Hamid
ahamidplg at gmail.com
Mon Aug 26 06:37:42 PDT 2024
I'am running on ubuntu 22.04 via nginx its not running on docker, site
url using hostname, this is configuration : geonode with nginx --->
reverse proxy (public ip), on SITEURL it's hostname self.
Br
Hamid
Pada 26/08/2024 17:24, Giovanni Allegri menulis:
> From logs, I suspect the upload is routed to the internal GeoNode
> proxy, which is unexpected.
> I think you have something wrong with your configs. Double-check the
> settings related to SITEURL.
> Is it a Docker?
> Giovanni
> On Mon, Aug 26, 2024 at 9:23 AM Abdul Hamid via geonode-users
> <geonode-users at lists.osgeo.org> wrote:
> Hi all
> I tried to upload ESRI data into geonode (using geonode 4.2.5) but
> after selecting the file and clicking upload there was a failure,
> as shown in the image below
> Geonode
> this is log taken from /var/log/geonode.log
> Internal Server Error: /proxy/
> Traceback (most recent call last):
> File
> "/home/admina/.virtualenvs/geonode/lib/python3.10/site-packages/django/core/handlers/exception.py",
> line 47, in inner
> response = get_response(request)
> File
> "/home/adminkominfo/.virtualenvs/geonode/lib/python3.10/site-packages/django/core/handlers/base.py",
> line 181, in _get_response
> response = wrapped_callback(request, *callback_args,
> **callback_kwargs)
> File
> "/home/admina/.virtualenvs/geonode/lib/python3.10/site-packages/django/utils/decorators.py",
> line 130, in _wrapped_view
> response = view_func(request, *args, **kwargs)
> File "/opt/geonode/./geonode/proxy/views.py", line 185, in proxy
> _data = request.body.decode("utf-8")
> File
> "/home/admina/.virtualenvs/geonode/lib/python3.10/site-packages/django/http/request.py",
> line 330, in body
> raise RawPostDataException("You cannot access body after
> reading from request's data stream")
> django.http.request.RawPostDataException: You cannot access body
> after reading from request's data stream
> Thank You
> Br
> Hamid
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
> GeoServer Professional Services from the experts!
> Visit http://bit.ly/gs-services-us <http://bit.ly/gs-services-us>for
> more information.==Dott. Giovanni Allegri
> Technical Lead / Project Manager
> GeoSolutions Groupphone: +39 0584 962313cell: +39 345 2815774
> fax: +39 0584 1660272 https://www.geosolutionsgroup.com/
> <https://www.geosolutionsgroup.com/>http://twitter.com/geosolutions_it
> <http://twitter.com/geosolutions_it>-------------------------------------------------------
> Con riferimento alla normativa sul trattamento dei dati personali
> (Reg. UE 2016/679 - Regolamento generale sulla protezione dei dati
> “GDPR”), si precisa che ogni circostanza inerente alla presente email
> (il suo contenuto, gli eventuali allegati, etc.) è un dato la cui
> conoscenza è riservata al/i solo/i destinatario/i indicati dallo
> scrivente. Se il messaggio Le è giunto per errore, è tenuta/o a
> cancellarlo, ogni altra operazione è illecita. Le sarei comunque grato
> se potesse darmene notizia.This email is intended only for the person
> or entity to which it is addressed and may contain information that is
> privileged, confidential or otherwise protected from disclosure. We
> remind that - as provided by European Regulation 2016/679 “GDPR” -
> copying, dissemination or use of this e-mail or the information herein
> by anyone other than the intended recipient is prohibited. If you have
> received this email by mistake, please notify us immediately by
> telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20240826/79304603/attachment-0001.htm>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20240826/79304603/attachment-0001.png>
More information about the geonode-users
