[GeoNode-users] Custom CRS in GeoNode
Giovanni Allegri giovanni.allegri at geosolutionsgroup.com
Tue Aug 27 06:35:08 PDT 2024
You will probably get more support from the Geoserver ML, since this is
specific to Geoserver.
The mentioned documentation was taken as it is from Geoserver's one
<https://docs.geoserver.org/main/en/user/configuration/crshandling/customcrs.html>
On the side of GeoNode there a few, and very restricted, places where CRS
transformations are applied. For example, when a spatial filter inside the
filter panel is activated.
For these cases, the EPSG should be overridden inside the PostGIS data
table too.
Giovanni
On Tue, Aug 27, 2024 at 2:03 PM Rodrigo Marsillac Linn via geonode-users <
geonode-users at lists.osgeo.org> wrote:
> Hi all,
> We are trying to reflect in GeoNode the tables that are using our local
> coordinate system, the CRS_POA (http://leismunicipa.is/nsegk ). To work
> around the issue of a customized system, we followed the steps indicated in
> the documentation
> https://doc-geonode.readthedocs.io/en/latest/006_adv_workshop/003_geonode_production/adv_gsconfig/crs_handling.html#override-an-official-epsg-code
> , but when downloading the file as a shapefile, for example, the AUTHORITY
> attribute is maintained with the official EPSG.
> Is there any other way to work around this issue without having to modify
> the parameters of an existing EPSG code? Unfortunately, we have not yet
> obtained the EPSG code for our CRS-POA; we are still waiting for it. Once
> we receive it, will it be possible to insert this new code and visualize
> the layers through GeoNode, or will we need to wait for a version update?
> Thank you, everyone.
> R.
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information.
Dott. Giovanni Allegri
Technical Lead / Project Manager
GeoSolutions Group
phone: +39 0584 962313
cell:     +39 345 2815774
fax:      +39 0584 1660272
https://www.geosolutionsgroup.com/
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20240827/337d064f/attachment.htm>
More information about the geonode-users mailing list
