[GeoNode-users] Issue with SLD uploads in latest version of GeoNode
Giovanni Allegri
giovanni.allegri at geosolutionsgroup.com
Fri Feb 21 01:12:46 PST 2025
Hi Ramesh,
could you share the SLD?
Giovanni
On Fri, Feb 21, 2025 at 6:41 AM Ramesh De Silva via geonode-users <
geonode-users at lists.osgeo.org> wrote:
> Hi,
> I am experiencing some issues with SLD uploads with the latest stable
> version of the GeoNode. When I include a SLD (generated via QGIS) together
> with the dataset, it fails to draw the layer. The dataset I refer to here
> is a polygon dataset classified on a text field. In GeoNode "visual
> editor", the SLD rules were not shown as classification rules but as many
> simple styles. If I manually make any modifications to the style, it does
> not allow me to save the changes. I have tested this in GeoNode Stable Demo
> as well. The result was the same.
> I was able to smoothly upload the very same dataset together with the very
> same SLD file in GeoNode version 4.0.
> Any advice is greatly appreciated. Thank you!
> Kind Regards
> Ramesh
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information.
Dott. Giovanni Allegri
Technical Lead / Project Manager
GeoSolutions Group
phone: +39 0584 962313
cell: +39 345 2815774
fax: +39 0584 1660272
https://www.geosolutionsgroup.com/
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20250221/35065974/attachment.htm>
More information about the geonode-users
