[GeoNode-users] Remote WMS services with TIME dimension in geonode 4.3
Amedeo Fadini
amefad at gmail.com
Tue Oct 28 11:26:55 PDT 2025
Hi everybody,
I was wondering if it is possibile to publish a remote WMS layer with time
dimension in geonode 4.3...
the answer is: yes it is.
https://kmap.info-rac.org/catalogue/#/dataset/20224
Unfortunately it doesn't read parameters from getcapabilities, I set th
flag "has time" and the time range in the admin section but the timeline
control in mapstore client does not work properly.
To get the data I need to type in exactly one of the time slot available
(first day of month at midnight e.g. 2023-01-01 00:00).
I see also that the "animation step" setting could not be set to "1 month"
that would be enough if this settings is saved on the map.
Is there a way to configurethe layer in mapstore client with the proper
parameters (start, end, time step)?
Suggestions are welcome
Amefad
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20251028/3ec70d43/attachment.htm>
More information about the geonode-users
