[GeoNode-users] Remote WMS services with TIME dimension in geonode 4.3
Giovanni Allegri
giovanni.allegri at geosolutionsgroup.com
Wed Oct 29 02:56:57 PDT 2025
Hi Amedeo,
It depends on the support from the remote WMS server. The timeline tool in
MapStore is designed on the WMTS Multidimensional [1] module for Geoserver,
which implements the "Multidimensional WMTS domain discovery" extension [2]
proposal.
Indeed, the example you provide is not working. The very first request the
timeline widgets perform is a DescribeDomains request. This request fails
for that example, and if you try to run the animation you will see all
subsequent requests fail.
So, in theory, you should be able to use external time series resources if
they provide the expected support.
Giovanni
[1]
https://docs.geoserver.org/main/en/user/extensions/wmts-multidimensional/index.html#wmts-multidimensional
[2] https://demo.geo-solutions.it/share/wmts-multidim/wmts_multidim.html
On Tue, Oct 28, 2025 at 7:27 PM Amedeo Fadini via geonode-users <
geonode-users at lists.osgeo.org> wrote:
> Hi everybody,
> I was wondering if it is possibile to publish a remote WMS layer with time
> dimension in geonode 4.3...
> the answer is: yes it is.
> https://kmap.info-rac.org/catalogue/#/dataset/20224
> Unfortunately it doesn't read parameters from getcapabilities, I set th
> flag "has time" and the time range in the admin section but the timeline
> control in mapstore client does not work properly.
> To get the data I need to type in exactly one of the time slot available
> (first day of month at midnight e.g. 2023-01-01 00:00).
> I see also that the "animation step" setting could not be set to "1
> month" that would be enough if this settings is saved on the map.
> Is there a way to configurethe layer in mapstore client with the proper
> parameters (start, end, time step)?
> Suggestions are welcome
> Amefad
> geonode-users mailing list
> https://lists.osgeo.org/mailman/listinfo/geonode-users
GeoServer Professional Services from the experts!
Visit http://bit.ly/gs-services-us for more information.
Dott. Giovanni Allegri
Technical Lead / Project Manager
GeoSolutions Group
phone: +39 0584 962313
cell: +39 345 2815774
fax: +39 0584 1660272
https://www.geosolutionsgroup.com/
Con riferimento alla normativa sul trattamento dei dati personali (Reg. UE
2016/679 - Regolamento generale sulla protezione dei dati “GDPR”), si
precisa che ogni circostanza inerente alla presente email (il suo
contenuto, gli eventuali allegati, etc.) è un dato la cui conoscenza è
riservata al/i solo/i destinatario/i indicati dallo scrivente. Se il
messaggio Le è giunto per errore, è tenuta/o a cancellarlo, ogni altra
operazione è illecita. Le sarei comunque grato se potesse darmene notizia.
This email is intended only for the person or entity to which it is
addressed and may contain information that is privileged, confidential or
otherwise protected from disclosure. We remind that - as provided by
European Regulation 2016/679 “GDPR” - copying, dissemination or use of this
e-mail or the information herein by anyone other than the intended
recipient is prohibited. If you have received this email by mistake, please
notify us immediately by telephone or e-mail.
URL: <http://lists.osgeo.org/pipermail/geonode-users/attachments/20251029/f4b621d2/attachment.htm>
More information about the geonode-users
