[Geoprisma-dev] Layer loading problem
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Dec 4 20:16:22 EST 2009
Yves,
Here are some examples of using loadend event on a layer:
I think this is doing exactly what you want:
http://n2.nabble.com/How-to-stop-registering-events-td3911670.html
Some other random ones:
layer.events.register("loadend", layer, function() {
console.log(layer.features.length); });
http://trac.openlayers.org/browser/trunk/openlayers/examples/layerLoadMonitoring.html
Found these in:
http://www.google.com/#hl=en&source=hp&q=openlayers+event+loadend+example
Hope this helps.
-Steve
Yves Moisan wrote:
>> Yves,
>> http://dev.openlayers.org/releases/OpenLayers-2.8/doc/apidocs/files/OpenLayers/Layer-js.html
> Hi Stephen,
> Thank you for your answer. I've seen the reference page many times, but
> I would prefer a simple tutorial. I mean, what I'm doing is relatively
> simple ...
>> scroll down to the EVENTS.
>> But it might be easies to to just set a delay timer that fires once and
>> selects the feature.
> I like that much less because you are at the mercy of the network.
> Events are way better IMO. Just gotta find out what the machinery is.
> Thanx for your input.
> Have a good weekend,
> Yves
>> var mylayer = new OpenLayers.Layer....
>> mylayer.events.register("loadend", objtoselect, function(e) {
>> // select object this
>> // unregister event handler
>> -Steve
More information about the Geoprisma-dev
