[Geoprisma-users] bdga config.xml
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Nov 25 23:20:10 EST 2009
Alexandre,
Following through your tutorial, I pick the bdga demo to use as a model
for my project. I noticed it does not have a config.xml in the samples
directory.
A little more investigation shows:
diff common.php /u/geoprisma/projects/corsicana/config/.
20c20
< org_geoprisma_SettingImpl::setXMLConfigFile("$strCurrentDir/config.xml");
org_geoprisma_SettingImpl::setXMLConfigFile("$g_strConfigDir/config-bdga.xml");
which appears to be located at trunk/config/config-bdga.xml
Also the bdga sample does not have a template.xslt file either. Maybe is
is not a good sample to use as a base to clone.
For my first project (this might be too complicated), I have gotten this
far:
1) loaded all the data into postgis
2) can server all the data via WMS and mapserver
3) installed featureserver, but have no idea how to configure it with
the data in postgis
What to build an application with the following:
Resources Services Actions Roles
+ GYMO Read all
fmroads +
highways |
interstate | WMS, FS ALL roads_dept
serviceroads | Read all
streets +
onemileetj +
citylimits |
lakes | WMS, FS ALL gis_dept
votingprecincts | Read all
railroads +
parcels + WMS, FS ALL tax_dept
Read all
zoning + WMS, FS ALL zoning_dept
Read all
You mentioned getting started with the NO_ACL driver and then add the
ACLs later.
This probably means I need the following widgets:
QueryOnClick for read only users
FeaturePanel_Form for create, update users
FeaturePanel_Selector or ResultExtGrid? for read only users
GeoExtToolbar or Toolbar
MousePosition
MeasureTool
Scale
EditFeature widgets for the create, update users
Merge widgets for the create, update users
Split widgets for the create, update users
Others not listed in
http://geoprisma.org/dist/naturaldoc/files2/featurepanel/form/Form-txt.html
but are in the samples.
Is there a better sample to look at? Or just start with one and then add
widgets to it as Iget each in turn working.
-Steve
More information about the Geoprisma-users
