[geos-devel] Status Report (October 15)
Norman Vine
nhv at cape.com
Tue Oct 22 22:27:51 EDT 2002
Paul Ramsey writes:
> OK, having diff'ed up this tarball, it looks like 99% of the changes are
> -at(x)
> +[x]
> in addition to that there are a bunch of changes to the build
> envirnoment to account for the new files. Norman, could you commit the
> changes to the build environment ASAP, for a start?
Done
Norman
Checking in configure.in;
/home/cvs/postgis/geos/configure.in,v <-- configure.in
new revision: 1.7; previous revision: 1.6
done
Checking in source/Makefile.am;
/home/cvs/postgis/geos/source/Makefile.am,v <-- Makefile.am
new revision: 1.5; previous revision: 1.4
done
Checking in source/geom/Geometry.cpp;
/home/cvs/postgis/geos/source/geom/Geometry.cpp,v <-- Geometry.cpp
done
Checking in source/geom/GeometryCollection.cpp;
/home/cvs/postgis/geos/source/geom/GeometryCollection.cpp,v <--
done
Checking in source/geom/Makefile.am;
/home/cvs/postgis/geos/source/geom/Makefile.am,v <-- Makefile.am
new revision: 1.6; previous revision: 1.5
done
Checking in source/geom/Polygon.cpp;
/home/cvs/postgis/geos/source/geom/Polygon.cpp,v <-- Polygon.cpp
done
Checking in source/graph/Depth.cpp;
/home/cvs/postgis/geos/source/graph/Depth.cpp,v <-- Depth.cpp
new revision: 1.2; previous revision: 1.1
done
Checking in source/graph/DirectedEdgeStar.cpp;
/home/cvs/postgis/geos/source/graph/DirectedEdgeStar.cpp,v <--
done
Checking in source/graph/EdgeEnd.cpp;
/home/cvs/postgis/geos/source/graph/EdgeEnd.cpp,v <-- EdgeEnd.cpp
new revision: 1.3; previous revision: 1.2
done
Checking in source/graph/EdgeEndStar.cpp;
/home/cvs/postgis/geos/source/graph/EdgeEndStar.cpp,v <-- EdgeEndStar.cpp
done
Checking in source/graph/EdgeIntersection.cpp;
/home/cvs/postgis/geos/source/graph/EdgeIntersection.cpp,v <--
done
Checking in source/graph/EdgeList.cpp;
/home/cvs/postgis/geos/source/graph/EdgeList.cpp,v <-- EdgeList.cpp
done
Checking in source/graph/EdgeRing.cpp;
/home/cvs/postgis/geos/source/graph/EdgeRing.cpp,v <-- EdgeRing.cpp
done
Checking in source/graph/PlanarGraph.cpp;
/home/cvs/postgis/geos/source/graph/PlanarGraph.cpp,v <-- PlanarGraph.cpp
done
Checking in source/graph/Quadrant.cpp;
/home/cvs/postgis/geos/source/graph/Quadrant.cpp,v <-- Quadrant.cpp
done
Checking in source/graph/index/MonotoneChainEdge.cpp;
/home/cvs/postgis/geos/source/graph/index/MonotoneChainEdge.cpp,v <--
done
Checking in source/graph/index/SegmentIntersector.cpp;
/home/cvs/postgis/geos/source/graph/index/SegmentIntersector.cpp,v <--
done
Checking in source/graph/index/SimpleMCSweepLineIntersector.cpp;
/home/cvs/postgis/geos/source/graph/index/SimpleMCSweepLineIntersector.cpp,v
<-- SimpleMCSweepLineIntersector.cpp
new revision: 1.4; previous revision: 1.3
done
Checking in source/graph/index/SweepLineEvent.cpp;
/home/cvs/postgis/geos/source/graph/index/SweepLineEvent.cpp,v <--
SweepLineEvent.cpp
done
Checking in source/operation/GeometryGraphOperation.cpp;
/home/cvs/postgis/geos/source/operation/GeometryGraphOperation.cpp,v <--
done
Checking in source/operation/relate/RelateComputer.cpp;
/home/cvs/postgis/geos/source/operation/relate/RelateComputer.cpp,v <--
RelateComputer.cpp
done
Checking in source/test/CTS.cpp;
/home/cvs/postgis/geos/source/test/CTS.cpp,v <-- CTS.cpp
done
Checking in source/test/SimpleWKTTester.cpp;
/home/cvs/postgis/geos/source/test/SimpleWKTTester.cpp,v <--
SimpleWKTTester.cpp
done
Checking in source/test/XMLTester.cpp;
/home/cvs/postgis/geos/source/test/XMLTester.cpp,v <-- XMLTester.cpp
done
