[geos-devel] proposing debian support diff
strk at refractions.net
Fri Nov 19 11:35:55 EST 2004
Alex, I've added the files you provided to GEOS CVS
but I cannot handle to build a .deb neither on debign 3.0
nor on testing/unstable.
Can you provide instructions in a README and/or a Makefile
codifing the process of building it ?
TIA
--strk;
On Sat, Nov 13, 2004 at 03:36:29AM +0200, alex bodnaru wrote:
> hello friends,
> i am using debian linux, and i've made the files additions needed to
> make GEOS compile and install on a debian system.
> the attached diff contains one directory, debian/ which should be in the
> geos distribution root directory: e.g /usr/src/geos/geos-2.0.1.
> making the debian packages uses standard geos making procedures.
> no changes have been made to any file originally found in geos.
> geos version and dependencies are being automatically deduced, so no
> change should be needed to the debian files upon geos upgrading.
> please include debian files in the geos distribution, for all debian
> geos users to benefit.
> best regards,
> alex
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
