[geos-devel] geos in Pythoon
strk at refractions.net strk at refractions.net
Mon Oct 18 08:46:47 EDT 2004
I've provided the swig module with appropriate build scripts.
Next produced snapshot should contain it.
--strk;
On Fri, Oct 15, 2004 at 07:28:34AM -0600, Sean Gillies wrote:
> On Oct 15, 2004, at 4:34 AM, Niki Spahiev wrote:
> >On Fri, 15 Oct 2004 11:03:53 +0200, strk at refractions.net
> ><strk at refractions.net> wrote:
> >>If you don't see a swig/ directory in that package this means
> >>the SWIG part did not handle to go in 2.0.1 distribution.
> >>Pull down a CVS snapshot to take a look at it.
> >http://geos.refractions.net/geos-cvs.tar.bz2 has no swig files as well.
> Niki,
> You may have to pull it directly from CVS if it is not in the
> nightly snapshot.  I've also got it available from my own website
> until the situation is corrected
>   http://users.frii.com/sgillies/projects/geos-swig.tgz
> Download, copy into your GEOS directory and extract.
> cheers,
> Sean
> Sean Gillies
> sgillies at frii dot com
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
