[geos-devel] Undefine references in libgeos_c 2.2.3
strk at refractions.net
Mon Jul 10 06:20:42 EDT 2006
Do you mean you're using -lgeos -lgeos_c ?
One problem might be that libgeos_c.so *knows* which version
of libgeos.so to link against, while manual link could pick up
a wrong one (ie: manual -lgeos would link against 3.0.0 while
libgeos_c.so from 2.2.3 needs to use libgeos.so from 2.2.3!)
--strk;
On Mon, Jul 10, 2006 at 09:22:09AM +0200, Mateusz Loskot wrote:
> Hi,
> Yesterday, one of GDAL users reported that GDAL CVS does not build
> with GEOS 2.2.3.
> I investigated the problem and noticed two issues.
> The first one is related to GDAL autotools (already fixed).
> But the second one seems to be related to GEOS itsef.
> I downloaded fresh GEOS 2.2.3 release and build it in standard way:
> $ ./configure
> $ make
> $ sudo make install
> Next, I checkouted GDAL from CVS and tried to build it too.
> The libgdal library builds and links well, but linking
> OGR utilities fails with following message:
> /bin/sh /home/mloskot/tmp/gdal-cvs/gdal/libtool --mode=link g++
> ogrinfo.o /home/mloskot/tmp/gdal-cvs/gdal/libgdal.la -o ogrinfo
> g++ ogrinfo.o -o .libs/ogrinfo
> /home/mloskot/tmp/gdal-cvs/gdal/.libs/libgdal.so -L/usr/local/lib
> -L/usr/lib -lpq -lrt -ldl -lpthread
> /usr/local/lib/libgeos_c.so.1: undefined reference to
> `geos::WKBReader::read(std::basic_istream<char, std::char_traits<char> >&)'
> `geos::WKBWriter::write(geos::Geometry const&, std::basic_ostream<char,
> `geos::Point::getCoordinatesRO() const'
> `geos::WKBWriter::WKBWriter(int, int)'
> collect2: ld returned 1 exit status
> make[1]: *** [ogrinfo] Error 1
> make[1]: Leaving directory `/home/mloskot/tmp/gdal-cvs/gdal/ogr'
> make: *** [ogr-apps] Error 2
> I checked 2.2.3 sources and all calls listed above are declared (.h) and
> defined (.cpp) properly.
> It seems to be a problem with -lgeos -lgeos_c linking but I'm not sure.
> Any ideas?
> Cheers
> Mateusz Loskot
> http://mateusz.loskot.net
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
/"\ ASCII Ribbon Campaign
\ / Respect for low technology.
X Keep e-mail messages readable by any computer system.
/ \ Keep it ASCII.
