[geos-devel] A word about Javisms
Paul Ramsey pramsey at refractions.net
Thu Mar 23 22:45:46 EST 2006
I should point out here, that the JTS relationship has been virtuous
in both directions. The GEOS community has had performance issues
which for some reason the JTS using community has not, and this has
resulted in a number of efficiency ideas which have migrated from the
GEOS list and implementations back into JTS as Martin saw the merit
in them.  (Primarily rather simple short-circuit ideas which were not
required for JTS correctness but make a big difference in the Real
World when things start getting exercised.)
P
On Mar 23, 2006, at 7:39 PM, Paul Ramsey wrote:
> It means that porting concepts, bug fixes, and new algorithms from
> JTS to GEOS not be made difficult by differences in the code
> bases.  Why?  Because the limiting factor in the development of
> GEOS is not C++ coding expertise, it is computational geometry and
> geometric algorithm expertise.  We are lucky to be able to sponge
> off of Martin Davis' work in JTS, and in particular his expertise
> in the subject matter area.  The years of experience Martin has are
> not easily replicable, so even when we have clients asking us for
> improvements specifically in PostGIS/GEOS (and we do), it makes
> sense to have Martin do them in JTS and then port them, when they
> are algorithmic and conceptual in nature.
