[geos-devel] Namespaces and headers split
Sean Gillies
sgillies at frii.com
Fri Mar 24 09:00:49 EST 2006
On Mar 24, 2006, at 6:40 AM, Mateusz Ĺoskot wrote:
> Paul Ramsey wrote:
>> Won't be time until Monday or Tuesday next, as I am away until
>> then... you can use the intervening time to be sure you are sure...
> I'm just pushing a proposal with hope that Sandro will make a good
> decision.
> I agree with SVN, but also if Sandro will decide it's not necessary
> and my proposal is not good, then situation is clear ;-)
> p.s. It's not a secret that I'm often like a demon
> whispering from behind your shoulders ;-)))
And maybe a serious issue tracker? Once you've got SVN going, Trac
(just an example) is not at all hard to install and admin.
cheers,
Sean
Sean Gillies
http://zcologia.com
