[geos-devel] Re: Problems with installation of geos on RedHat 9
(third try, i hope this is text)
strk at refractions.net
Thu May 18 06:49:52 EDT 2006
On Thu, May 18, 2006 at 12:44:47PM +0200, Johan V wrote:
> Well, now i got a lot further, but still not to the end. The configure
> output is a bit the same i think, but this is the make output:
You're gettin the *same* error from make.
How about checking with 'ls' whether BufferBuilder.h is there?
Are you sure you're grabbing code with a cvs client ?
Can you see CVS subdirectories in each dir ?
Please only report a couple of lines before the actual error
and any warning (the next time, if you really need it)
--strk;
