[geos-devel] Building GEOS with GDAL
strk at refractions.net strk at refractions.net
Wed Nov 15 12:30:45 EST 2006
On Wed, Nov 15, 2006 at 09:20:57AM -0800, Paul Ramsey wrote:
> On 15-Nov-06, at 9:59 AM, Frank Warmerdam wrote:
> >It does still really suck that I have to configure geos on unix
> >just to
> >get a geos_c.h.vc (which I copied from the geos_c.h produced on unix).
> >Hopefully the rules for producing the packaged source tarballs (as
> >opposed
> >to pulling from SVN) will produce geos_c.h.vc for distribution?
> If you pull geos-svn.tar.gz, the snapshot source, you'll find that it
> has been auto-generated.
The ./configure scripts generates from geos_c.h.vc.in, which is
out of sync, unless I'm missing something.
> So, do we drop the whole .vc thing, because it is out of date and
> unmaintained?  Or do we maintain it up to a level of utility?  Do we
> revert the .in generation (all it gains us is automatic
> synchronization with the version information from the top of the tree)?
I suggest we only generate geos_c.h, but also distribute it.
Trying this now..
--strk;
