[geos-devel] Building GEOS with GDAL
Wed Nov 15 13:54:26 EST 2006
strk at refractions.net wrote:
> On Wed, Nov 15, 2006 at 09:20:57AM -0800, Paul Ramsey wrote:
>> On 15-Nov-06, at 9:59 AM, Frank Warmerdam wrote:
>>> It does still really suck that I have to configure geos on unix
>>> just to
>>> get a geos_c.h.vc (which I copied from the geos_c.h produced on unix).
>>> Hopefully the rules for producing the packaged source tarballs (as
>>> opposed
>>> to pulling from SVN) will produce geos_c.h.vc for distribution?
>> If you pull geos-svn.tar.gz, the snapshot source, you'll find that it
>> has been auto-generated.
> The ./configure scripts generates from geos_c.h.vc.in, which is
> out of sync, unless I'm missing something.
>> So, do we drop the whole .vc thing, because it is out of date and
>> unmaintained?  Or do we maintain it up to a level of utility?  Do we
>> revert the .in generation (all it gains us is automatic
>> synchronization with the version information from the top of the tree)?
> I suggest we only generate geos_c.h, but also distribute it.
> Trying this now..
Strk,
Dropping the geos_c.h.vc entirely would be fine if distributed source
files include geos_c.h, but then we will need to remove the rule for
copying geos_c.h.vc to geos_c.h from the source/Makefile.vc.
I'd be wiling to try a fixed up source distribution if you guys like.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
