[geos-devel] Patch: Fixing GEOS HEAD compilation under MingW
Ari Jolma
ari.jolma at tkk.fi
Thu Jan 4 12:12:17 EST 2007
Mark Cave-Ayland kirjoitti:
> Sure. I found a second copy of ld.exe and a few other utilities
> in /mingw/mingw32 even after I had upgraded the binutils package.
there is /mingw/mingw32 is in binutils-2.17.50-20060824-1.tar.gz
> The
> solution for me was to extract the latest binutils package
> (binutils-2.17.50-20060824-1.tar.gz) in /mingw/, and then move
> the /mingw/mingw32 directory somewhere safe outside of /mingw/.
I removed /mingw/mingw32 and, when updating, did not extract it from the
new tar.gz
> I then found that re-running configure allowed libtool to find the
> version of ld.exe in /mingw/bin rather than /mingw/mingw32/bin, and the
> linking problem disappeared. I'd be interested to hear whether this
> solves the problem for you.
The compilation now works after rerunning configure and with the libtool
it creates. The problem seems to be solved. I just don't understand when
/mingw/mingw32 is needed.
Thanks,
Ari
> Kind regards,
> Mark.
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
Prof. Ari Jolma
Geoinformaatio- ja paikannustekniikka
Geoinformation and positioning technology
Teknillinen Korkeakoulu / Helsinki University of Technology
POBox 1200, 02015 TKK, Finland
Email: ari.jolma at tkk.fi URL: http://www.tkk.fi/~jolma
