[geos-devel] Patch: Fixing GEOS HEAD compilation under MingW
Charlie Savage
cfis at savagexi.com
Thu Jan 4 17:48:11 EST 2007
Hi Mark,
Thanks for making this work - I had no luck before. I've also noticed
that some functions that were not previously defined in MingW are now
defined in the latest versions (off the top of my head infinity I think
was one, but would have to check). Did you run into any problems like that?
Charlie
Mark Cave-Ayland wrote:
> On Wed, 2007-01-03 at 18:28 +0200, Ari Jolma wrote:
>> Mark Cave-Ayland kirjoitti:
>>> I've just discovered that the issue with ld.exe crashing was a problem
>>> with my MingW setup - I've fixed this, and just completed a clean GEOS
>>> build under MingW by downloading a fresh source and applying the patch
>>> from my previous email :D
>> Could you tell us what the problem was? I'm having similar problems with
>> MinGW/MSYS when building GDAL. I changed the max_cmd_len to 50000 and it
>> fixed the problem, but according to you my MinGW setup is faulty.
>> Ari
> Hi Ari,
> Sure. I found a second copy of ld.exe and a few other utilities
> in /mingw/mingw32 even after I had upgraded the binutils package. The
> solution for me was to extract the latest binutils package
> (binutils-2.17.50-20060824-1.tar.gz) in /mingw/, and then move
> the /mingw/mingw32 directory somewhere safe outside of /mingw/.
> I then found that re-running configure allowed libtool to find the
> version of ld.exe in /mingw/bin rather than /mingw/mingw32/bin, and the
> linking problem disappeared. I'd be interested to hear whether this
> solves the problem for you.
> Kind regards,
> Mark.
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20070104/6be3eea4/smime.bin
