[geos-devel] Assertion Failure with VC++ and STRtree:yComparator
Charlie Savage
cfis at savagexi.com
Wed Sep 12 19:39:01 EDT 2007
Following up on my email from a couple weeks ago.
Any opinions? What is now checked in is broken in debug builds for VC++
which I think is unacceptable (makes it a lot hard to run GEOS under the
VC++ or WinDebug debuggers).
I want to revert to strk's original version ... but his comments worry me.
Charlie
Charlie Savage wrote:
> There appears to be a fairly serious issue with the trunk version of
> GEOS with STRtree:yComparator(Boundable *a, Boundable *b).
> There are various comments from mloskot and strk about how the
> comparison should work. Choices seem to be:
> return STRtree::centreY(aEnv) < STRtree::centreY(bEnv);
> Or
> return std::fabs( STRtree::centreY(aEnv) - STRtree::centreY(bEnv) ) < 1e-30
> Currently, the second option is used. But on Windows, using a debug
> VC++ build, that is almost guaranteed to cause an assertion failure.
> VC++ has code in xutility that checks the comparison in both directions:
> template<class _Pr, class _Ty1, class _Ty2> inline
> bool __CLRCALL_OR_CDECL _Debug_lt_pred(_Pr _Pred, _Ty1& _Left, _Ty2&
> _Right,
> const wchar_t *_Where, unsigned int _Line)
> { // test if _Pred(_Left, _Right) and _Pred is strict weak ordering
> if (!_Pred(_Left, _Right))
> return (false);
> else if (_Pred(_Right, _Left))
> _DEBUG_ERROR2("invalid operator<", _Where, _Line);
> return (true);
> Assume the centers of the two envelopes are equivalent - that will
> trigger the 2nd part of the if statement causing an assertion failure.
> Can this be fixed so that the comparison works as expected? The first
> version does the trick, but strk wrote some scary comments that it
> corrupts memory in some cases (although with a quick glance I don't see
> how).
> Thanks,
> Charlie
> geos-devel mailing list
> geos-devel at geos.refractions.net
> http://geos.refractions.net/mailman/listinfo/geos-devel
Type: application/x-pkcs7-signature
Desc: S/MIME Cryptographic Signature
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20070912/07e397a5/smime.bin
